GrandL 4060 with LA1055 loader?
   / GrandL 4060 with LA1055 loader? #1
glock 123
northeast
j deere 420
Anybody have one?
I assume you can get the heavier rated loader on the L4060. Price wise how much more is the LA1055 versus the LA805.
   / GrandL 4060 with LA1055 loader? #2
Might check with L4060, landedakioti, Nightwind15, or Peterc38, they all have L4060s.
   / GrandL 4060 with LA1055 loader? #3
Jeff; I must have missed LA1055 on build Kubotas site.? All I get is LA805?
   / GrandL 4060 with LA1055 loader? #5
In Kubota's Operator's Manual for the FELs LA555/LA805/LA1055, the LA1055 is shown as available on the L4760, L5060, L5460 & L6060.
For the L4060 only the LA805 is shown as available.
Note that dimensions for L4060 are 121.5' X 66.5"; for L4760 are 126" X 67.3", so it is unlikely the LA1055 is dimensioned to fit the frame of an L4060. There would also be the question of front end strength of L4060 versus heavier L4760.
You will have to move up to the larger framed L4760 to get an LA1055 FEL.
I have an LA805, paired with the optional L2296 Heavy-duty, Round-Back Bucket, on my L3560. It is a strong combination.
If you are truly moving up from a Deere 420 Lawn & Garden tractor I would not get hung up on the difference between the LA805 and LA1055 FELs. You really need to have a 50% increase in lift before you get a WOW! difference when operating.
I have had air in the rear Industrial Tires on all three of my tractors as I run over people's lawns regularly. With air in the rear tires, rather than liquid, I need to mount a counter-balancing implement on the Three Point Hitch before I accomplish near-max lifts (Photo #2, #3), otherwise the rear end lifts, instead of the FEL load. With moderate lifts, including a full bucket of Florida sandy-loam, rear ballast is not absolutely necessary but rear ballast takes strain off the front axle and front bearings. Quite often I use an ETA Cultipacker as ballast (Photo #1). It is heavy and compact. Other times I utilize a Bush Hog (brand) Rollover Box Blade (Photos #2,#3,#4).
{Above assumes level ground.}
Thanks Jeff! That must be why it does not show on the build for a 4060
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
