3-Point Hitch Mahindra 7520 4wd with 275 loader / lift arms don't work
   / Mahindra 7520 4wd with 275 loader / lift arms don't work #1
Motorheadtoo
Cordova, Md
Mahindra. 7520
Dealer replace engine under warranty. Since replacement the rear 3pt lift arms has not worked. Oil and filters has been changed. All remotes been checked at 2600 psi. Lift arm levers are not stuck. Dealers said there is no oil flow charts so I can see if I can chase the problem that way. Been four yrs since lift arms has worked.
   / Mahindra 7520 4wd with 275 loader / lift arms don't work #2
It was the dealers problem. Too late now I guess.
Dealer didn't have anybody that knew anything about Hyd They took 8 months to change engine.
   / Mahindra 7520 4wd with 275 loader / lift arms don't work #4
8 months to R&R an engine ! flat rate without looking i'd guess is only 20hr 0r so. I looked at the JIC schematic for you tractor. its in the work shop man. That dealer was blowing smoke up you 6. 3pt lift valve is at end of line. Check you draft control feed back linkage adj. Do you have a FEL on this unit?:confused3:
   / Mahindra 7520 4wd with 275 loader / lift arms don't work #5
I'm guessing that the lift is all the way up and won't go down. Is this correct?
If so, push the 3pt control lever all the way forward, then open the valve (under your seat just above the floor) a few turns and see if it goes down.
If I'm wrong....never mind. :)
   / Mahindra 7520 4wd with 275 loader / lift arms don't work #6
The 7520 does not have a manual valve to limit down speed. It automatically senses weight and adjusts to prevent a quick fall of a heavy implement.
,,, OP has not given sufficient info to make any educated guess as to the nature of the problem.
   / Mahindra 7520 4wd with 275 loader / lift arms don't work #7
Well then, as I said, never mind. :)
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2014 JCB 930 (A57148)
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
Deere 35G (A53317)
Deere 35G (A53317)
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
