Christmas Project - snowblower chute automation
   / Christmas Project - snowblower chute automation #1
whiskywizard
Southern Ontario, on Lake Ontario
KIOTI CK20S HST
I had the kids all home for Christmas so the 3 boys - me, my son and my son-in-law - decided to celebrate the season properly by doing a little fabrication and drinking some beer in the garage.
Nothing ground-breaking here, but it has tested out OK, and I'm happy with it. Now I'm looking forward to some snow so I can try it in anger. :laughing:
   / Christmas Project - snowblower chute automation #2
Do you have the cable wrapped around the chute? The pictures look like it's not fully wrapped. I gave mine an extra wrap to make sure I wouldn't bind it up.
What did you use for the deflector actuator? I haven't added that yet but yours looks pretty high tech.
   / Christmas Project - snowblower chute automation #3
If that winch is the Harbor Freight one (looks a lot like it) the little relay box that comes with it is not waterproof. Mine froze solid last winter!! I replaced it with an ATV winch control from Amazon.
   / Christmas Project - snowblower chute automation #4
On my similar set up I made a motor cover from a short length of 4" sewer drain pipe.
Where the cute rotates and makes contact with the blower body I made up a wide 'washer' using plastic sheet stock.
The chute rotates more easily when sliding on plastic vs metal on metal. Grease also helps.
   / Christmas Project - snowblower chute automation #5
What is the load on the defletor? I have a spare $60 actuator rated to 200lbs or so I was thinking about deploying like that. Have the winch for lifting the jeep plow too. Its obselete as the plow is now SSQA & curl does the lifting. Might try the same setup you have.
The cable isn't fully wrapped around the chute. It terminates behind the chute, secured to two large nuts I welded there.
The deflector is driven by a linear actuator. $74 at Princess Auto.
The winch is an ATV unit, from Princess Auto. It included at circuit breaker but no relay. I added a relay up near the battery. It's weatherproof but also pretty well protected there.
My LA is rated for 135lb dynamic and 200lb static load. I hope it is strong enough.
Good suggestions. My winch is rated for immersion so it should withstand the weather. I have enough gap in the chute cylinder for some thin plastic; I'll keep that in mind.
   / Christmas Project - snowblower chute automation #10
BOC whiskywizard? Small world!
Sorry for the threadjack.
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
2021 CATERPILLAR CB2.7 DBL DRUM ROLLER (A52705)
2021 CATERPILLAR...
2016 NISSAN VERSA Sedan (A53424)
2016 NISSAN VERSA...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2005 JLG 660SJ TELESCOPIC MANLIFT (A52705)
2005 JLG 660SJ...
Toro Mower (A50324)
Toro Mower (A50324)
