Massey Ferguson 165 fiberglass repair under starter ??
   / Massey Ferguson 165 fiberglass repair under starter ?? #1
Quebec MF165
Shannon
Massey Ferguson 165
Hi everyone !!
I recently bought a Mf 165 1968 with a Perkins AD4 203 engine. The engine was pretty dirty when I bought it and with the loader attachement I did not notice everything when buying it... I was cleaning some dirt on the engine when i noticed a fiberglass patch under the starter. It is very cold this week in Quebec to be removing and inspecting behind the starter so I was just wondering what could crack or be damaged behind that? I used maybe 3 hours since i got it pushing snow and playing around getting used to the machine ( my first tractor by the way) and i have not noticed anything yet from that area.
Thank you for reading :)
   / Massey Ferguson 165 fiberglass repair under starter ?? #2
Picture?
Hi everyone !!
Thank you for reading :)[/QUOTE
Evidently there must be some kind of crack or damage under that patch/repair .... maybe one of the previous owners blew a piston connecting rod and punctured the case ?? Can this be welded or a better idea to repair :) Thanks
   / Massey Ferguson 165 fiberglass repair under starter ?? #5
G'day
I'd say correct it has thrown a rod at some time and cracked the block, it is only splash oil behind there so if it is not leaking I would leave well enough alone just keep an eye on it
Jon
   / Massey Ferguson 165 fiberglass repair under starter ?? #6
what about the rest of the engine ? How is your oil pressure when warm (should be around 40 psi). Need to check a few other things first.
A fibre glass repair on the engine casing is not necessarily bad and can last a very long time. If an engine rebuild has been done it should be ok but there is a need to check out the area properly. How big an area is the patch - if small then probably fine.
The rest of the engine seems good. Runs nice and smooth. Cant say much about the oil pressure . I dont trust the oil pressure gauge . It's pretty worn out.. The patch is about as big as the starter motor and have not taken a look with the starter removed yet but checked with a mirror. Looks oily a bit and will try to seal it better this spring. I am a little disappointed that i did not see it when I bought it. But if the engine blew before and was repaired properly maybe i am better off with a "repaired engine" with a patched casing than one who is close to blow something inside. Keeping my fingers crossed :)
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
FAKE (A52472)
FAKE (A52472)
