1953 TO 30 Fuel valve / sediment bowl replacement,
   / 1953 TO 30 Fuel valve / sediment bowl replacement, #1
Chopp62
SW VA
1952 Ferguson TO 30
The fuel valve stem seals gave way on my TO-30, leading to a persistent fuel leak, even with the valve off. New parts are on the way.
I'm wondering, any tricks to installation of the new assembly? Do I assume the threads into the gas tank are NPT, requiring no sealer?
   / 1953 TO 30 Fuel valve / sediment bowl replacement, #2
You'll have to drain the tank to install it. I use Teflon tape when I install it. make sure that the sediment bow assembly to get has the dal standpipes so that you have the reserve capability . That will save you some grief if to you forget to fill it and you run the tank down to the reserve level.
Thanks, Jerry/MT. I had heard about Teflon tape and wanted to confirm.
As to draining the tank, my property is steep enough that I can park with the right front wheel downhill and uncover the pickup with a fairly low fuel level.
   / 1953 TO 30 Fuel valve / sediment bowl replacement, #4
Some lil tape, I usually don't, but I I do, use yellow, and avoid thin strips or shreds that can clig carb ports.
I usually use gasoila or similar paste , but either work..
PNEUMATIC GREASE UNIT (A53843)
PNEUMATIC GREASE...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
2016 CHEVROLET 2500 TRUCK (A51247)
2016 CHEVROLET...
10" I BEAMS & 10" CHANNEL IRON UP TO 40' LONG (A51247)
10" I BEAMS & 10"...
378812 (A51573)
378812 (A51573)
Athey 7-12D Force Feed Loader (A52384)
Athey 7-12D Force...
