Used Massey Ferguson Gc 2610 parts.
   / Used Massey Ferguson Gc 2610 parts. #1
renegade1958
Boundary Creek, New Brunswick, Canada
GC2610 TLB
Hello everyone. I am looking for a source for used parts for my Massey Ferguson GC2610 tractors. Just took the rear PTO shaft out to replace the bearings and I found that I had major bearing failure and as a result have a broken transmission housing where the bearing sits so as a result I am going to be lookin g for a transmission housing. Any help would be greatly appreciated. Thanks
   / Used Massey Ferguson Gc 2610 parts. #2
Now that will be a bit of a pickle...
Can you get us a picture where it cracked?
Also you can try to get it welded and then grind the required hole for the bearing...
Otherwise finding a donor will be quite the feat...
   / Used Massey Ferguson Gc 2610 parts. #3
You'll need to double check my findings... Go here Object moved to confirm the part number for the housing. It appears that housing was used on 4 different models, but even at that, only found one, doing a quick search http://www.tractorhouse.com/list/partssearch.aspx?partnum=4264907M2&pst=starts.
However, I went directly to Wengers site, and ran the part number, but got no result. I guess a phone call would be your best bet, to check. You could at least get a price, and compare to having it repaired, if that is possible, and cost effective.
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
John Deere 1110 Field Cultivator - Heavy-Duty Soil Finisher for Precision Tillage (A53473)
John Deere 1110...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
2014 International PayStar 5900i S/A Flatbed Truck (A52377)
2014 International...
TORO MBTX 2500 STAND-ON CONCRETE BUGGY (A51406)
TORO MBTX 2500...
