Mf30 engine rebuild?Perkins 4cyl diesel
   / Mf30 engine rebuild?Perkins 4cyl diesel #11
It's a 1973 MF 30 industrial (loader/backhoe) with a Perkins AD4.203
Yea, I don't think it is the smaller mf30.
Doesn't that mean it has dry sleeves?
What are the odds the sleeves don't need to be removed? I have no idea if and when they have ever been removed. But the tractor has plenty of power and has good compression....
   / Mf30 engine rebuild?Perkins 4cyl diesel #13
If you have a broken piston ring why do you need to change the sleeves?
Is the bore badly scored? If not can you just do a hone? Then do rings ,bearing shells (big ends only as you are leaving the crank in), and seals.
Well, I don't have motor apart. I don't know that I have a broken ring. I think It is likely a broken ring. It has bad "blow by" but plenty of power and runs great. As long as oil is constantly replenished. Sound like a broken ring?
If it is just a broken ring, you don't think the broken ring would have scarred the sleeves up bad enough to need replacing?
   / Mf30 engine rebuild?Perkins 4cyl diesel #15
Its not the small one, you may get away with new rings.
   / Mf30 engine rebuild?Perkins 4cyl diesel #16
The dry sleeves can be hard to pull out, you must have a puller.
Do you know if the front end loader has to come off in order to remove the head and see how the sleeves look? Would this be a huge undertaking just to get to the sleeves and check them out?
   / Mf30 engine rebuild?Perkins 4cyl diesel #18
Just take the head off on the engine, should not be an big job. Just clean as much as you can before you begin.
   / Mf30 engine rebuild?Perkins 4cyl diesel #19
X2 on getting it as clean as you can before taking it apart. Rent, or barrow a pressure washer if you don't have one.
Another thing it could be is that the piston rings collapsed thus not giving you a good seal. After you get the head, oil pan off, and get the pistons out for a closer look.
Club Car Electric Utility Cart (A55853)
Club Car Electric...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
John Deere 3025E (A53317)
John Deere 3025E...
2021 Ford F-450 (A55973)
2021 Ford F-450...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
