JerryG
Super Member
If the lever is moving to easy, the roll pin which holds the lever to the shaft may be sheared. Have someone move the lever as you see if the shaft is turning with the lever.
First time it has happened and when needed the most . Any suggestions ?? tractor stopped , clutch in , nothing ! and without it the **** thing will not move in the snow
Dealer told me to put it in low gear and slowly move forward and reverse while trying to engage , it worked finally. Dealer said what you said , not even close enough to being too cold. I plan on hauling it to dealer for him to check it out anyway in Ashland VA . Gears not lining up ? Love the tractor just picked a bad time with 20 inch snow
