'Feet' on rear blade
   / 'Feet' on rear blade #1
oldpilgrim
Elite Member
SE Ma
2014 Mahindra 3016HST
Does any one have 'feet' on their rear blade?
I resurfaced my driveway with crushed dense pack stone just before winter. Spread it, rolled it and vibator packed it and it gave a good hard surface. With the freeze and that cycles we have about daily, after our first snow, I used my rear blade and I ended up moving too much gravel as it snowed on a freshly thawed surface.
Second storm, the ground was frozen and it worked great. Last year all the snow came on top of frozen ground and it worked great.
I thought this year, I'd put some feet on the blade to keep it from letting the blade go down too deep when the ground is soft. I bought some plow feet from TSC and made some mounts to bolt on the blade. Finished it this afternoon, just in time, as we're expecting rain and snow tonite and tomorrow.
After I bolted them on, I took it out onto the driveway, not frozen, as we've had 2-3 days in the high 50's.
I set the blade down on the feet, the blade about 1 inch from the driveway and moved the tractor a little, leaving two 'furrows' where the feet set on the stone.
Who has feet on their blade? What's your experience with them?
   / 'Feet' on rear blade #2
I think that you will have better luck with them if you can get them dished some. Mine are about 1/2" if I remember correctly.
   / 'Feet' on rear blade #3
You didn't have any issue with it digging into the ground? bet will be much better when the ground is frozen though
   / 'Feet' on rear blade #4
You may need skis Op . I have an area with crushed rock and the only thing that works for me there is pushing with the plow backwards over it.
they are dished about 1/2"
Buyers S.A.M. Snowplow Aftermarket Manufacturing Plow Shoe - For Life Out Here
They will be better when the ground is frozen. I actually don't need them then. That's the reason I put them on, for use on thawed ground, but I'm not sure they're going to work the way I was hoping.
I thought of skis, but they are very narrow and I was afraid they would leave 'skid marks', much like these round feet seem to. :(
   / 'Feet' on rear blade #7
Ahhh I see what your sayin... need something like the tooth off a rockrake that has a bit of give to it.. cut it down and flip it around backwards... may still be to tough in soft thawed ground
   / 'Feet' on rear blade #8
Well, they look flat to me. :confused2: If the ground is soft, it's going to leave marks, not much you can do.
   / 'Feet' on rear blade #9
2 long grooves are better than gouging out 6 feet I say! :eek:
Its tough year here in the Northeast. The weather's been wet and warm and the ground is still soft. I have had mud season twice already :laughing:
I have only plowed one time this year and that was the week after Christmas. I didn't even want to either, knowing how soft the ground was but it was wet heavy snow and the immediate forecast was for well below freezing temperatures for several days after so I saddled up and did the deed.
Weren't a pretty sight :confused2:
Shoes should be a help, I used to push a lot of snow with 6 ft wide worksaver blade from the old CT store on the back of my tractor and I wanted the shoes the offered they were folded steel and slotted for adjustment. Never did get them but the best thing I ever did was get a hydraulic top link and used that to quickly adjust the blade angle even as I was moving :D
Loose material is tough...reversing the blade sometimes helps.
   / 'Feet' on rear blade #10
You need to reverse the blade on soft drives.
Like this. )O=o going this way =>
Dual/Moyno Pump System (A50121)
Dual/Moyno Pump...
1993 Ford Ranger Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
10ft x 8ft Container with Side Door (A51573)
10ft x 8ft...
Mini Excavator (A50121)
Mini Excavator...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
