Massey GC1705 Hood Modifications
   / Massey GC1705 Hood Modifications #1
jlgurr
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
Has anyone, by chance, had an experience with drilling holes in their hood? I'm thinking it would be easy as the material appears to be a simple molded plastic. Just curious if there is something I should know before hand to prevent a catastrophe. The two holes I need to drill will be approximately 5/8" diameter.
Thanks,
Jeff
   / Massey GC1705 Hood Modifications #2
Iirc, it's steel hood. Not plastic. Put a magnet on it and check. Put masking tape before u mark the holes. It prevent paint from chipping. Then use a step drill to go to 5/8 in. Since its thin sheet steel.
Wow, I better be more careful on my assumptions. Will take a closer look at it next time it's uncovered. Thank you Clipse!
Sent from my iPhone 2.0 using TractorByNet
   / Massey GC1705 Hood Modifications #4
Yeah no plastic hoods on the MF. Just JDs. The masking tape is key to prevent chipping while drilling. Definitely use a step drill. Then clear coat the holes to prevent rust.
   / Massey GC1705 Hood Modifications #5
You also need to restore the corrosion protection when you finish.
You will have bare metal where the edge of the hole is.
Depending on what you are doing, some type of sealer could do that.
You also need to restore the corrosion protection when you finish. You will have bare metal where the edge of the hole is. Depending on what you are doing, some type of sealer could do that.
yep, and I purchased rubber grommets to go in the holes and protect the wires/tubes going through the holes.
02-07-2016 10:33 PM
   / Massey GC1705 Hood Modifications #7
Fill the rubber grommet outer ridge that seats in the hole with some RTV. Easy to wipe it when fresh prevents water from getting under the rubber grommet collar.
Neat idea! Thanks.
   / Massey GC1705 Hood Modifications #9
The rubber grommets will attract and hold water, through capillary attraction. If there isn't sufficient corrosion protection, there can be corrosion.
Because grommets are soft, and can move, the only thing that would work well with a rubber grommet, would be to paint it first. Or, use some type of coating, that will dry hard like paint. This could be done with a brush in this case. Keep in mind that paint does not like to cover sharp edges, so, it may take some effort, and several coats. As, well as allowing a good amount of time for drying, prior to installing the grommets.
I do not recommend silicone for sealing a grommet. Or, much else, actually. (Aquariums, and bathtubs excepted). However, it would be better than nothing. And, may be enough in this application.
Silicone calk is not ideal on bare metal. I have never seen it used by any automotive manufacturer for a sealant, or corrosion protection.
There are sealants that don't harden at all, like butyl. which would be better. But they are not always easy for the general public to get. Or, inexpensive.
This gutter sealant, is inexpensive, and sticks to bare metal, as well as painted surfaces extremely well: Shop OSI Gutter Sealant at Lowes.com It is not ideal, but would be a superior choice over silicone. It is very handy to have around the house, once you try it.
I have considerable experience, and training, and certifications in auto body repair, and painting.
Boy o boy, what a wealth of information you can find here on TBN and from the members. Thank you for bringing all these considerations to me. To provide a little more info, I will be adding a dash mount pair of gauges to my tractor and mounting them on the hood. (Reminds me of how dad's old Farmall M looked.) Well, anyway the holes and grommets will be under the plastic console the gauges are mounted in. So, if I do my job correctly they will never see moisture from above and only from the engine side. Of course, that's only in a perfect world, right? :D
I'll be sure to prep the drilled hole surfaces to accept a good coating of primer and paint then after very adequate drying time (which should not be too hard since this project has progressed at a snail's pace) I will use Ray's suggestions on installing the grommets. The console I've purchased for the gauges I am hoping to install with adhesive to the painted hood rather than drilling additional small screw holes for mounting.
Can't wait to share photos of the finished work with you all!
2002 KENTUCKY 53FT TRI AXLE MOVING TRAILER (A57880)
2002 KENTUCKY 53FT...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2008 Jeep Wrangler 4X4 SUV (A56859)
2008 Jeep Wrangler...
2014 Ford Escape SE (A56859)
2014 Ford Escape...
2014 BMW X3 XDrive28i AWD SUV (A55853)
2014 BMW X3...
2020 ASPT 16ft. T/A Flatbed Utility Trailer (A55853)
2020 ASPT 16ft...
