YM2200 Wiring Diagram
   / YM2200 Wiring Diagram #13
I'm with California. Winston Dia. is close but it's just a generic YM2000 Dia.. The 2200 has a clutch Safety Switch and other options. Let me know if you need it and I will try and find it for you.
   / YM2200 Wiring Diagram #14
Safety switch is shown, what other options are you talking about?
   / YM2200 Wiring Diagram #15
Which one? I'm looking at a dia. that has 2 in line looking real quick at a Dia.. Start Saftey and Start Safety PTO. It's looks to Labeled General Info and Dia. 240-0S-S Not sure Exactly what tractor but it's there. JD 240? could be 336? Don't know. Has a Front PTO. also.
   / YM2200 Wiring Diagram #16
Any other saftey switches will be in the same circuit with the clutch safety switch that is shown on the drawing I attached.
   / YM2200 Wiring Diagram #17
Does yours say YM220? so that would be No and No.
   / YM2200 Wiring Diagram #18
I like the version Winston linked best of all. Why?
Because it's a repost of the diagram I copied from the YM240 manual and posted here over 10 years ago, in this post. :D Wow, 34 thousand views!
I recognize my cropping every time it reappears.
I've reposted it here several more times in reply to threads such as this present one and I've seen others post it here. It appeared in post #4 above, until it later disappeared. (I think TBN revised how links work, at some point. If you look at Page Source for this page my link is still in that post).
At first glance the diagram in post #2 shows the same information as this YM240 diagram. Are there differences? YM2200 can't be that different, these were very simple tractors and production of YM240 (YM2000) began only slightly after YM2200.
Ok I went and compared the two diagrams. The only difference I see is Bruce's diagram in Post #2 has a separate switch for the thermostart (dashboard pushbutton) while my post has Yanmar's later ignition switch with 'twist key left for themostart'.
Here's a repost of mine again. This is a link to the January 2005 gif.
31855d1104721271-1610d-volt-reg-wells-vr728-557466-yam240elec-gif
   / YM2200 Wiring Diagram #19
I like Mine Better. Is there is a YM220 Dia. I think there is and that is just Generic Dia.YM2000 and not even a US version JD240 :p :rainbow::rainbow:
   / YM2200 Wiring Diagram #20
Don't know about a JD240 but that is definitely a YM240 schematic. A YM2000 or YM2200 schematic would be in Japanese.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
UNUSED Battery Powered 3 Wheel Golf Cart (A55272)
UNUSED Battery...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
