Bosch VE injection pumps KSB
   / Bosch VE injection pumps KSB
RickB, have you seen any issues with the common-rail systems with the Bosch CP3 pump and leak downs after sitting, causing an extended crank or operator having to work the priming pump before every start?
   / Bosch VE injection pumps KSB #22
Also found a small leak at the glass sediment filter, which was just a loose fitting.
Tied up a fuel can and submerged the disconnected lines in fuel. Tractor started quick. Idled until temperature came up and KSB switched off. No smoke and no putter!
Can't believe i didn't bypass the tank and try that sooner. I was so caught up in thinking it being a pump/timing issue. Should of remembered K.I.S.S., KEEP IT SIMPLE STUPID!
Good find! You were too close to the problem for some time. Going back to scratch and working forward always makes sense, when nothing else does. BTW, I'd still pop test your injectors. The pump is fixed, BUT the injectors could be leaking or have a bad spray pattern, which could lead to diluting your oil and scored cylinder wall(s).
   / Bosch VE injection pumps KSB #23
No, we have little experience with that system to date.
Is that because its less problematic or because it's not as common?
Pictures are worth a thousand words, so i figured i would add a few pertaining to this thread.
   / Bosch VE injection pumps KSB #26
Try Conestoga Diesel, I'm sure they can answer your questions, since current TBN members can't.
2016 FORD F-550XL SUPER DUTY SERVICE TRUCK (A52706)
2016 FORD F-550XL...
UNUSED 84" HYD ROCK GRAPPLE (A52706)
UNUSED 84" HYD...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
INDUSTRIAS AMERICA 20' LOADING RAMP (A52706)
INDUSTRIAS AMERICA...
