Apparent axle shaft oil leak on rear rims-why? Photos included.
   / Apparent axle shaft oil leak on rear rims-why? Photos included. #1
tmac196
Temperance, MI
1951 Ford 8N, 1965 Ford 2000, Grasshopper 325D, JD 5065M
Yesterday, I noticed the left rear rim of my 8N was stained with oil in a pattern which indicated (to me) that differential oil was leaking out of the hub area and has been for some time. I have enclosed two photos. One of the leak evidence and a second of the "hub". What is the source of this problem. Is it an axle shaft seal going bad? Is there more than one seal in the axle shaft/hub assembly?
http://i1200.photobucket.com/albums/bb321/tmac196/IMG_1881.jpg
http://i1200.photobucket.com/albums/bb321/tmac196/IMG_1882.jpg
   / Apparent axle shaft oil leak on rear rims-why? Photos included. #2
Since you have a 51 model, there are 2 axle seals. Here's a link to a good rundown on doing the job:
Replacing Rear Axle Seals in 8N Ford Tractors
It's interesting that yours leaked all the way out to the end. Do the brakes work on that side? On mine, the seal failed and it leaked into the brake drum causing the brakes to stop working. It's not a difficult job. Also, make sure your differential fluid isn't over filled, as that could increase the chances of leakage. Here's some info on that:8N Axle seals replacement vs. quic... - Yesterday's Tractors
   / Apparent axle shaft oil leak on rear rims-why? Photos included. #3
we need to see the hub fit to the axle.. if the splines are flush or proud, the hub and or the axle is worn.
   / Apparent axle shaft oil leak on rear rims-why? Photos included. #4
Clogged vents will cause axle leaks. When pressure builds up inside the differential then fluid will find a way to escape.
   / Apparent axle shaft oil leak on rear rims-why? Photos included. #5
shouldn't on this type of a ford...
static oil should be setting BELOW the seal level.
leaks like this on a ford are seals soooo bad that splash oozes thru.. and of course.. overfilled too..
plenty of places on this old ford common sump for gas to relieve.. no real 'vents' as such.. but the dipstick ain't air tight. :)
Indeed, the brakes do not work on that side. Thanks for the links. They are very helpful.
It is probably advisable to replace the 2 seals on each side if I'm going to do one side. I'll need to drain the sump and I should do that just once...
   / Apparent axle shaft oil leak on rear rims-why? Photos included. #7
No need to drain the sump, the oil level should be below the axle seals. If the level is high enough to spill out the axle housing when you remove the axle, that's part of your problem right there: too much oil.
Ahhh....makes sense. Thanks for all of the help.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2025 INDUSTRIAS AMERICA FT510 5' X 10' HYD DUMP TL (A51247)
2025 INDUSTRIAS...
2021 Ford F-250 4x4 Ext. Cab RKI Service Truck (A52377)
2021 Ford F-250...
UNUSED FUTURE FT1000J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
1998 CATERPILLAR 120H MOTORGRADER (A51406)
1998 CATERPILLAR...
