Electrical advice needed
   / Electrical advice needed #41
I apologize for not responding promptly to all the well intentioned responses. I've been busy with quite a few things. It seems everyone has been curious about the machine in question. It is a planer molder and this is directly from the manual; Motor is 230 volt, 30 amps. Recommended receptacle is 6-30R.
My brother's son in law is a commercial electrician with around 20 years experience. He has agreed to help with the wiring, and I feel comfortable with his competence. Although I haven't talked to him yet, I will defer to his recommendations.
Again thank you for all the good responses. As always TBN is a treasure trove of knowledge.
TNhobbyfarmer, Could you please update us on what your nephew-in-law recommends for your wiring solution please?
I think it would be a benefit to other members.
Good luck with your project.
Dave :thumbsup:
   / Electrical advice needed #42
That is one big machine! Will produce a big pile of wood shavings I think. Horse bedding?
   / Electrical advice needed #43
Motor circuits are calculated based on horsepower of the motor. For single phase motors look in table 430.248 to get your circuit amperage. Conductors are then calculated at 125% of the table ampreage rating and the circuit breaker can be 250% of the table amperage rating. If the cb size falls in between manufactured sizes, you may select the size up.
I do this for a living.
If FLA really is 30.0 Amp. The 6-30R is too small. The classic 6-50 welding receptacle and plug would be code compliant. Of course the 6-50R would work with just about an modern welder.
Not quite sure why welders got brought into the mix here. The machine is not a welder.
Motor circuits are calculated based on horsepower of the motor. For single phase motors look in table 430.248 to get your circuit amperage. Conductors are then calculated at 125% of the table hp rating and the circuit breaker can be 250% of the table amperage rating. If the cb size falls in between manufactured sizes, you may select the size up.
Based on the information I have supplied, can you recommend a wire size and amperage for the breaker? That's all I am asking.
   / Electrical advice needed #47
Read the manual for the machine - Section 2 - http://cdn0.grizzly.com/manuals/g8622_m.pdf
Dedicated 30 amp breaker - We recommend using a NEMA-style L6-30 plug and outlet (which is a 3 wire cord)
Greg is correct. The manual says 5 hp motor will draw ~25 amps, which makes a 30 amp circuit too small. Code (table 430.248) says it will draw 28 amps, and you must size circuit based on this, which also makes a 30 amp circuit too small.
Will a 30 amp circuit work?: Most of the time.
Will it be safe: Yes, even if it does trip out occasionally.
Will it be to Code? The answer is obvious, but let's pretend it falls under Article 90.4: "...the authority having jurisdiction (AHJ) may waive specific requirements..."
   / Electrical advice needed #48
If it is indeed a 5 hp motor, you would be fine with 8 awg conductors with a 10 awg equipment ground run off of a 60 amp two pole breaker.
Motor circuits have their own rules.
   / Electrical advice needed #49
I am not versed in electrical code, and cannot cite anything....but protecting a 8ga circuit with a 60a breaker for an electric motor dont sound right?
   / Electrical advice needed #50
Greg, Assuming OP does what you say, what about the plug/receptacle?
Do you know of anything in the Code that says you can't put a 30 amp receptacle on a 60 amp circuit?
On one hand, anything with a 30 amp plug shouldn't draw more than 30 amps (or hopefully 24 amps),
...On the other hand, it doesn't feel right, but I can't find anything explicit in the code that says you can't.
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2005 INTERNATIONAL 9400I (INOPERABLE) (A53843)
2005 INTERNATIONAL...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53473)
2022 NEW HOLLAND...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
