sd455dan
Elite Member
- Joined
- Oct 23, 2012
- Messages
- 4,816
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
Wanted to weld aluminum with the old Lincoln that I picked up,as a back up for my little inverter welder.
Originally thought it would be easy because my sister has a newer Tig 300 with a foot pedal she was willing to lend me.
Unfortunately my old lincoln is a Mag amp controlled unit which requires a wire wound rheostat for current control. So had i hooked up the newer foot pedal and tried to weld the variable resistor would have been damaged.
This led me to search the internet for home built foot pedals since no ancient factory K 746 foot pedals seem to be available. I was able find an old military surplus Rheostat with the correct 1000 ohm resistance and ordered it.
Hooked it up with a test cord and sure enough the weld current could be controlled with no over heating of the the rheostat.
So threw together a wood based pedal to test the viability, ( please don't laugh to hard) know it looks like ----
Using a couple brackets supporting a pin vice clamped on the control shaft. the pin vice has a hole through the shaft to maintain the rheostats position.
Any way it worked. The only real problem was the heavy duty carpet thread stretched, so replaced it with 10 # steel fishing leader line.
Feeling fairly sure it was going to be ok , I purchased some 10 and 11 gauge steel from leftover cut offs from our local Pacific Steel.
Scribed some pieces out and plasma cut them with my lotos combo unit which did a decent job with fairly minimal dross to knock off.
Next added the rheostat and fishing line
, springs and such
and here it is next to the Lincoln foot pedal
my first attempts at welding some Aluminum .065 circular punch outs with the new pedal
I have a lot to learn and lots and lots of practice to do, but i was able to stick 2 Aluminum pieces together without blowing huge holes :cool2: (at least not on all of them:laughing
The total cost for the pedal was under $ 40. and ended up with about 1/2 of the 11 gauge steel unused.
I think this pedal will also work for my Lotos, LPTDC2000 for tig since the variable resistor in it is also a 1k unit.
The rheostats are electrically noisier- but going to try it, so ordered up some aviation 5 pin connectors that match the inverter welders connectors.
So far the pedal is working great and will also add a micro switch to free up my tig hand to concentrate on the arc and not holding the button down.
I really enjoyed building this
