Anyone using a Tisco leveling box for the lift arm?
   / Anyone using a Tisco leveling box for the lift arm? #2
Are you wanting to know about those specifically? Or just how much it helps? My jd 3020 has one, and I use it every time I hook up an implement that doesn't use a quick hitch
They look more effective than the turnbuckle style I have now. Are they effective and durable? The one at TSC is too long at a quick glance.
   / Anyone using a Tisco leveling box for the lift arm? #4
MY Bobcat CT 235 came with the crank style like this. Easy to use once I marked where level was. However have you thought about a hydraulic set up? Brian with Fit Rite can help
   / Anyone using a Tisco leveling box for the lift arm? #5
Would you be glad you ditched the turnbuckle style for gear & crank? Uh, yeah ... by the second time you adjusted for level, if not the first.
Good product & price? I'd say so, having paid ~$100 for similar (CAT-1)) for my T1520. Dealers may have several sizes, so it pays to call around and see who has such bits on hand. (you might be surprised)
Fitment? Measure for length/travel, width of the top mount, spread of lower clevis, and hole diameters to use existing pins.
I milled the top mount of mine narrower (~1/8"/side) for a 'drop fit', tool-free install. (Prep/paint along the way) Could have taken my OEM arm to compare size (advise to do so), but got lucky by knowing the pin dimensions and seeing ~ what I needed on the rack.
btw, Fluid Film to lube gears, threads, pins by default here. ;)
   / Anyone using a Tisco leveling box for the lift arm? #6
You can find these from aftermarket suppliers, and in several different lengths.
My 3 old Fords all have leveling box assemblies, but my tractors are old.
I just put a replacement assembly on my Ford 1920, and it was not listed as being for the 1920, but had the exact same parameters as the original.
I do not know why manufacturers quit putting these on new tractors.
I would not want to be without mine.
I think about Brian's TnT all the time but not justifiable at this time.
Thanks for your feedback fellas, this is good info. I'll ask around to see if anyone locally has my size.
   / Anyone using a Tisco leveling box for the lift arm? #8
I know this is a old thread, but I have the same problem now on my 1920. Would you be so kind as to tell me what part number you used? I think the Tisco SBA37001042 would work. Like to know for sure before buying one. Thanks
   / Anyone using a Tisco leveling box for the lift arm? #10
I wish I could tell you what part number I used, but I am out of the USA until November, so don't have access to receipts for my 1920 parts.
I have just purchased a valve and cylinder to build a hydraulic tilt for my 1920, because I cannot reach the leveling box from the seat of my 1920, like I can from my 8N.
Volvo A40D Off Road Dump Truck (A56438)
Volvo A40D Off...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
20' 1 Trip Shipping Container (A59814)
20' 1 Trip...
Case 1840 Skidsteer (A59814)
Case 1840...
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
