MOTOR QUITS WHEN I PULL SWITCH TO ENGAGE MOWER OR SNOWBLOWER ATTACHMENT
   / MOTOR QUITS WHEN I PULL SWITCH TO ENGAGE MOWER OR SNOWBLOWER ATTACHMENT #11
If your engine running as it should? I had this issue on a mower and it turned out to be the carb needing cleaning was not running with the torque it was suppose to.
   / MOTOR QUITS WHEN I PULL SWITCH TO ENGAGE MOWER OR SNOWBLOWER ATTACHMENT #12
First stem in trouble shooting....how is it dying?
Are the mower blades "attempting" to run and its just too much load on the tractor? (bad clutch, clutch air gap, spindle bearings seized, etc)
Or is the motor dying as if you just turned the key off? And mower blades arent even attempting to engage? (safety circuit or something else electronically)
Depending on "how" its dying, there would be two totally different diagnostic proceedures
   / MOTOR QUITS WHEN I PULL SWITCH TO ENGAGE MOWER OR SNOWBLOWER ATTACHMENT #13
I agree^^^
   / MOTOR QUITS WHEN I PULL SWITCH TO ENGAGE MOWER OR SNOWBLOWER ATTACHMENT #14
Don't think that the LX had a backup safety switch.. the electric PTO field coil may be dead shorted
2017 Ram 4500 Bucket Truck (A53473)
2017 Ram 4500...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
2002 14ft S/A Utility Tilt Trailer (A51694)
2002 14ft S/A...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
