Help! Can't get exhaust pipe out of end of muffler
   / Help! Can't get exhaust pipe out of end of muffler #1
Amos1
West-Central Illinois
Ford 861 Powermaster
I'm trying to replace the rusted-out exhaust and tail pipe on my Ford 801.
I Can Not get the exhaust pipe to slide out of the muffler...
I cut the pipe off about 5 or 6 inches from the muffler so I would have enough clearance to rotate and pull on the pipe, hoping it would slide out. I AM Able to rotate the pipe around freely and wiggle it up and down somewhat, but I still can't get it to slide out of the muffler :thumbdown:
I'm about ready to unbolt the muffler exhaust flange from the exhaust manifold so I can take the muffler and stuck exhaust pipe into the garage to try and remove the pipe.
If push comes to shove, I'll buy a new muffler so I can insert the new exhaust pipe in it. BUT - I'm kinda worrying if I'll have problems getting the muffler of of the exhaust flange, too. (I've read you Do Not want to get too rough with the manifold as it might crack. That would make my head hurt even more, not mention my wallet)
Anyone else ever had this problem - exhaust stuck in muffler? If so, how did you solve the issue?
Thanks for any suggestions !!!
   / Help! Can't get exhaust pipe out of end of muffler #2
Take a grinder and cut off wheel and carefully make a few relief cuts vertically in muffler .
By vertically, you mean a cut from the big part to towards the snout, correct? (There are 1 or 2 I can see that were already made on the muffler, but I'll try cutting 1 at a time and see it that works.)
Great idea! Thanks, Kevin
   / Help! Can't get exhaust pipe out of end of muffler #4
WD40 and heat ( torches) the muffler if yo can, the muffler will expand so you can pull the tail pipe out.
   / Help! Can't get exhaust pipe out of end of muffler #5
Yep and a small chisel might help . Good luck .
   / Help! Can't get exhaust pipe out of end of muffler #6
With a sawsall or hacksaw blade make a cut from the end of the exhaust pipe to the end inside the muffler with out cutting into the stub from the muffler. then take pliers and twist the pipe as if trying to roll it up long way. It should slide right out.
   / Help! Can't get exhaust pipe out of end of muffler #7
If it is in this tight, it may be just as difficult to get the new one in without a pipe expansion tool. How much does a muffler cost? That tool could be pricey.
   / Help! Can't get exhaust pipe out of end of muffler #9
I'm thinking that if the pipe will rotate, it is probably trapped in a groove caused by a muffler clamp. Probably have to whip up some kind of puller to extract it and then take the groove out of the muffler with a HF pipe expander so the new pipe will go all the way in.
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2012 CATERPILLAR 316EL EXCAVATOR (A51406)
2012 CATERPILLAR...
2018 MACK CHU613 DAYCAB (A53843)
2018 MACK CHU613...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
2001 STERLING DUMP TRUCK (A54756)
2001 STERLING DUMP...
John Deere BD1108 (A50123)
John Deere BD1108...
