Gravel floor in shed
   / Gravel floor in shed #1
TNhobbyfarmer
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I have a storage/implement shed with a dirt floor. When I walk in there after walking through dew covered grass, my boots get pretty nasty. If I walk in the house and forget to take off my boots, it makes a big mess.
I am considering putting in a gravel floor. Anybody done this? Are there any downsides I'm not considering?
   / Gravel floor in shed #2
My "Kioti Den is 0-3/4 gravel. Packs hard, is not nasty at all, and makes a good base. I can't think of any downsides. gotta be way better than the mud.
   / Gravel floor in shed #3
Just one caveat...if you use gravel with fines (especially something as hard as granite etc...)...wet shoe soles will pick up some of the fines that will act like sandpaper on finished wood or vinyl etc. floors...
   / Gravel floor in shed #4
Pea gravel (small rounded wash stone) should work. But with many work boots/shoes you have no assurance you won't drag them in with you. I have a rug at the garage door, one when I enter the house, one inside the house. Would certainly be better than mud though.
   / Gravel floor in shed #5
The only problem is if you ever have to get down on your knees to work on something you will need a pad. Ed
   / Gravel floor in shed #6
I am going to put stonecrete in mine this spring - should work great
   / Gravel floor in shed #7
I have an old horse barn on my new property that had a dirt floor and In hated it. I got a load or two of road gravel and spread and packed it down with a roller, now all is good. Not as good as concrete but doable. It is much easier to work in and much drier.
   / Gravel floor in shed #8
I have a gravel floor in one side of my barn and it packs down and works well . The only problem I have is moisture . The rocks stay dark in some places indicating moisture seeping up. I would suggest a heavy plastic ground cover then gravel.
Googled stonecrete. Appears to be a decorative/stamped type concrete. Seems kinda expensive for a shed.
Sounds like a solid idea.
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
1 pallet of Tool box /Pump/5 safety cones (A53117)
1 pallet of Tool...
2015 INTERNATIONAL PROSTAR (A53843)
2015 INTERNATIONAL...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
