Chipper Bent/Warped Chipper Rotor Repair?
   / Bent/Warped Chipper Rotor Repair? #1
mroberts5
Bucks County, PA
Ford/NH 1920
The flywheel on my Wallenstein BX40 is badly warped. I've inquired w/ Wallenstein about a replacement, but I'm not holding my breath.
Has anyone had experience have a warped flywheel repaired? Any recommendations in the SE Pennsylvania area?
For what its worth, I took measurements around the flywheel, and the warping is generally symmetrical.
   / Bent/Warped Chipper Rotor Repair? #2
The only thing that matters is that the knives are in one plane. How do they look as they pass the anvil?
Posted too soon. Just lined everything up and its running beautifully.
It was up to 1/8 out of plane, but the knives lined up good.
   / Bent/Warped Chipper Rotor Repair? #4
Sounds like my BX62s. Measured at the very outside of the flywheel is might be as much as an 1/8 of an inch. Measured at the anvil/blade interface its less than 1/64th of an inch. Chip on!!!
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
cummins generator (A56857)
cummins generator...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2013 Ford Explorer AWD SUV (A55853)
2013 Ford Explorer...
2005 Freightliner Sportcoach Elite MH401TS 40ft. Class A Motorhome (A55853)
2005 Freightliner...
