LT133 13HP Kohler surging at idle
   / LT133 13HP Kohler surging at idle #1
lipancreek
Member
TX
JD 5065e, Ford 5610S
The engine is surging a lot at idle, but as soon as I put a load on it by turning on the blades it runs great. Any ideas how to fix this? Thanks for any help.
   / LT133 13HP Kohler surging at idle #2
Check linkages and springs for wear, especially where arms fit into holes.
   / LT133 13HP Kohler surging at idle #3
Have you had this tractor for a while?
Has the surging just started?
I see that you are in Michigan. Are you using this for snow removal?
It could be just the cold weather.
Found this on a JD support site for your tractor:
Adjusting Carburetor
NOTE: Carburetor is calibrated by the engine manufacturer and is not adjustable.
If engine is operated at altitudes above 1829 m (6,000 ft.), some carburetors may require a special high altitude main jet. See your John Deere dealer.
If engine is hard to start or runs rough, check the troubleshooting section of this manual.
Possible engine surging will occur at high throttle with transmission in "N" neutral and mower engagement lever disengaged. This is a normal condition due to the emission control system.
After performing the checks in the troubleshooting section and your engine is still not performing correctly, contact your John Deere dealer.
Most of the time when the engine surges at idle it means that the fuel mixture is to lean, but as there is no adjustment, you may have to just live with it.
Also as someone else suggested, there could be some slop in the linkage.
Richard
   / LT133 13HP Kohler surging at idle #4
What you describe is the classic partially blocked idle circuit in the carb. You will need to remove the carb, give a it a good cleaning, and install a carb repair kit. What most people don't realize is an engine runs on the idle circuit even at full throttle, until you apply a load, and then it pulls fuel off of the main/high speed jet.
   / LT133 13HP Kohler surging at idle #5
Ding ding ding. Id bet a six pack you are right.
Thanks everyone. Its being used in TX so definitely not cold. I will check out the carb...
2025 CFG Industrial MH12RX (A50123)
2025 CFG...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
2015 Chevrolet Ambulance (A52377)
2015 Chevrolet...
