MF205 Starter
   / MF205 Starter #1
WhirldWorks
Member
Rockdale, Texas
Massey Ferguson MF205
Here we go again...no sooner did I get the head gasket replaced and now the dang thing won't start. I turn the key and sometimes I get nothing and sometimes I get a few clicks (with a fresh battery).
I'm thinking I might have burnt the starter up when it had the cylinder head problem, but I dunno. Is this a starter problem or the solenoid?
   / MF205 Starter
Wow, almost 400 views and no replies. Oh well...bought a new starter, new battery and new cables...and guess what...NOTHING CHANGED. I'm fed up with this "bargain deal" tractor,
   / MF205 Starter #3
What happens if you jump it with a wire?
   / MF205 Starter #5
Check the ground cabel one more time.
   / MF205 Starter
I guess it would help if I actually installed all the new stuff I bought. I installed everything but the new ground wire. I guess I was so frustrated I overlooked that. Anyway, I took the old one off, made sure the ground connection was clean and installed the new one. It starts now :)
I must say though, this new starter is worlds better than the old one before it died. Sometimes I'd have to try 2 or 3 times at 5 seconds each turn of the key to get this thing started. Now I barely turn the key and she's running!
   / MF205 Starter #8
Great to hear :)
   / MF205 Starter #9
where did you buy your starter and did you get any info on the manufacturer, I need a stater for a hinomoto e14
   / MF205 Starter
I ordered mine through Sears for about $280, but the manufacturer was actually RareElectrical.com. Here is the link, but I am not familiar with thehinomoto. I will say that the mounting plate didn't fit exactly right and I had to grind it down to get it to fit around a part of the engine block that stuck out. Once I did that it slid in perfect and works like a charm. Sears.com
shuttle bus (A56858)
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A55315)
2023 Kubota L3560...
(12) SHEETS OF 3/4" OSB WOOD (A57192)
(12) SHEETS OF...
2016 VOLVO L45H WHEEL LOADER (A52707)
2016 VOLVO L45H...
20' CONTAINER (A57192)
2025 JMR Tree Boom Skid Steer Attachment (A55851)
2025 JMR Tree Boom...
