Largest Cylinder That Will Fit On Miller 350P
   / Largest Cylinder That Will Fit On Miller 350P #1
Farmall45b
White Bear Lake, Minnesota
2014 Kubota B2650 HSD Cab
Does anyone know of the largest gas cylinder that will fit on our Miller 350P carts? We are in midst of a lot of fabrication projects at work and going through a lot of shielding gas. We can store any more cylinders as the safety police will come down on us. I think we have as best I can tell, we have 150 CF cylinders. Wondering is something larger will fit? Our stock folks that order parts are not very helpful when we ask them to order a larger size or find out any information from out suppliers.
Thanks
   / Largest Cylinder That Will Fit On Miller 350P #2
I would be shocked if it didn't take at least a 250 CF bottle. And possibly a 330 CF bottle. A 250 CF bottle is 9 3/8-inches in diameter by 54 1/2-inches tall.
   / Largest Cylinder That Will Fit On Miller 350P #3
Shield Arc is correct, a 200 or 300 series cylinder will work. Be advised, a 300 size cylinder can make your welder a bit tippy and top heavy.
   / Largest Cylinder That Will Fit On Miller 350P #4
I agree. I would probably extend the axles or extend and add "duals".
image-121246464.png Terry
   / Largest Cylinder That Will Fit On Miller 350P #5
Here's a wheelbase comparison between one of my home made carts (on left) and my MM350P
Terry
   / Largest Cylinder That Will Fit On Miller 350P #6
My 252 easily carries a 330 C02/Argon and a 125 Argon at the same time.
   / Largest Cylinder That Will Fit On Miller 350P #7
Got 9" diameter bottles on my 252 also - and from Cyberwelds' site for the 350's optional DUAL running gear -
Millermatic 350/350P Dual Cylinder Rack 195299
"Customer Service: The Millermatic 350/350P Dual Cylinder Rack 195299 will handle 2 T size cylinders which measure 9 1/4" diameter by 60" tall"
Neither Cyberweld nor MM350P manual states what size bottle the single running gear takes, but probably same as the dual rack... Steve
   / Largest Cylinder That Will Fit On Miller 350P #8
Single running gear takes a standard 330 cu ft tank.
2007 JOHN DEERE 710J BACKHOE (A52707)
2007 JOHN DEERE...
2013 Ford F-150 4x4 Pickup Truck (A55852)
2013 Ford F-150...
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
