Oil & Fuel Deutz Fahr Agro Plus 67 (2013) hydraulics
   / Deutz Fahr Agro Plus 67 (2013) hydraulics #1
Erle
Sedalia, Missouri
Deutz Fahr Agro Plus 67, Massey Ferguson 40B, Massey Ferguson 50A, Massey Ferguson Super 90
Tractor has 1130 hours. Hydraulics work great for about an hour. After they get hot they will not lift(3 point or hydraulic ports) Have purchased all new filters, although I would expect this to be more of a pump issue than a filter problem. Need to know what kind of hydraulic fluid to replace with as I can't find Akros Multi fluid. Also pump location, testing / verification and possibly where to find a service manual for the tractor. Finding info for this tractor online is almost impossible. Only other problem with tractor is the M6 alarm.
   / Deutz Fahr Agro Plus 67 (2013) hydraulics #2
Build yourself a hydraulic system pressure gauge and test the live pressure in as many places as you can, both hot and cold.
Make a thoughtful table of the recorded values and see where the information takes you.
It may be a priority valve malfunctioning. Or a Pressure regulator not behaving properly. "filters or the exact type of fluid? I doubt it!
Thanks for your reply. I ordered a test gauge this morning. Should have it Friday or Monday.
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
2000 GENIE S-60 MANLIFT (A51246)
2000 GENIE S-60...
RING 2 STARTS HERE @ 9:30 AM (A51247)
RING 2 STARTS HERE...
2018 Ford Fusion Sedan (A51694)
2018 Ford Fusion...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A52377)
2012 Ford F-550...
1972 Baker 30ft Pole S/A Towable Trailer (A51692)
1972 Baker 30ft...
