1964 ford 4000 diesal where is neutral safety switch?
   / 1964 ford 4000 diesal where is neutral safety switch? #1
Phoenix Farm
Bradford,NY
Ford 4000 diesel
1964 ford 4000 diesel where is neutral safety switch?
   / 1964 ford 4000 diesal where is neutral safety switch? #2
probably doesn't have one, to old
   / 1964 ford 4000 diesal where is neutral safety switch? #3
The only safety switch on my '87? Yanmar is on the clutch pedal. I doubt you have any safety switches at all.
   / 1964 ford 4000 diesal where is neutral safety switch? #4
Top of the transmission cover 10 o'clock position. It has one wire and the housing is grounded to the cover with a star washer on the underside of the cover. Ground is returned through the bolts that hold the cover to the transmission case. This is the start (safety) switch, or is designed to be. Power is applied to the solenoid energizing coil via an on-off key switch but the tranny safety switch has to be pushed down to make the ground connection completing the energizing circuit.
That tractor should have a 4 terminal starter solenoid, definitely not a 3....2 large and 1 small. Neither of the small terminals shall connect to tractor chassis (ground) within the solenoid. If it does, the safety function is defeated and to start you would have to have a rotating 3 position switch....off on start.
I don't remember which shift lever, gear or hi lo lever or if both have slots in them to allow you to push down on the start switch, but one or the other will prevent the starter button from depressing if the tractor gearing is such that the tractor has the engine connected to the rear wheels allowing for movement when the engine starts.
In 65 a rotating 3 positon key switch was used and the 4 terminal solenoid and transmission were still used, but the safety switch was just that and the position of the shift/range levers determined if the switch was closed or not allowing the key switch to start the tractor in the start position.
Both my Fords are diesels.
I may not be the brightest in the bunch...
I just rechecked and my diesel Ford 4000 was manufactured June 1972. I regret giving the wrong year. I can only imagine how this changes things. Thanks for the response. Onward...
   / 1964 ford 4000 diesal where is neutral safety switch? #6
Well then it's a 3 cylinder and is setup like my 3000. Looking on the tranny cover you will see a rubber boot with an exit wire at the 10 O'clock position. It has a plunger that sticks down, or is pushed up depending upon the position of the gear selector lever(s)...again I forget which....I know the gear shifter controls it, not sure on the range lever.
So that switch is your safety switch. and if not in the right position (up or down, forget which) you have no current through your solenoid control circuit and it won't close and send power to the starter.
Need more ask.
   / 1964 ford 4000 diesal where is neutral safety switch? #7
Connect the two wires to trouble shoot.
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
JOHN DEERE LOT IDENTIFIER 112 (A53084)
JOHN DEERE LOT...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2019 JOHN DEERE XUV835M LOT IDENTIFIER 26 (A53084)
2019 JOHN DEERE...
CHAMPION 1 PERSON GAS EARTH AUGER (A51248)
CHAMPION 1 PERSON...
