Question about F150 Ford Automatic Hubs 1996 vintage.
   / Question about F150 Ford Automatic Hubs 1996 vintage. #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
Is it worth it to ditch the OEM Ford Factory optional automatic locking hubs with the "3 Screw Cover" for manual locking hubs on a 1996 F150?
If so there are several aftermarket hubs to choose from.
As I understand it the OEM really only work going forward and the vehicle has to travel a few feet minimum to engage... which might not be the best when max traction is needed immediately.
   / Question about F150 Ford Automatic Hubs 1996 vintage. #2
They were extremely fragile, and yes the vehicle has to be in motion for them to work... Wait until you're stuck and you usually break them when they try to engage.
OK... sounds like I should swap them out.
Warn, Mile Marker, Super Winch?
   / Question about F150 Ford Automatic Hubs 1996 vintage. #4
Warn is the only one I'm familiar with.
In reading it looks like any off serious off roader avoids automatic hubs in this vintage.
Going to order a set of locking ones today.
   / Question about F150 Ford Automatic Hubs 1996 vintage. #6
can't stand the auto hubs on any trucks
i have used them all. i prefer warn they were also ford OEM supplier for a long time
   / Question about F150 Ford Automatic Hubs 1996 vintage. #7
I had three trucks (83 F 250, 84 F 150 and a 92 F 150) The '83 and '84 each had manual locks (Warn and Ford OEM respectively) and the 92 was auto. My auto's never broke and the Warn and Ford OEM looked the same and took the same maintenance kit parts.
I think the 96 could be saved by taking apart and making sure everything slides inside...
The best I can tell the last time 4WD was used on this truck was 15 years ago... I know it does not engage... transfer case works fine.
Planned to order a set or lockers and my brother said it was not necessary... so I just left it at that.
This is the pickup I gave my nephew.
I do confess I miss driving it... something about a full size 8' bed 4wd pickup with a 5 speed manual that makes you one with the truck... it rode and handled well on the highway... 100% stock... as in springs and tire size... even Mom like riding in it once she climbed in!
2012 Ford F-150 Ext Cab 4x4 Pick-Up Truck (A55852)
2012 Ford F-150...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
2007 JOHN DEERE 710J BACKHOE (A52707)
2007 JOHN DEERE...
2015 CATERPILLAR 415F2 BACKHOE (A52707)
2015 CATERPILLAR...
2017 John Deere 8370RT Track Tractor (A53485)
2017 John Deere...
20711 (A50323)
20711 (A50323)
