Good morning!!!!
   / Good morning!!!! #43,461
weather forecast for next ten days is fifties at night, mid to high 70's during the day. I guess Spring has sprung.
Not a good night last night, lot of leg cramps from being on my feet way too long yesterday. Much less to do today, coat of poly on the raised garden wood, then finish painting my old Cub Cadet. After which I hope to do very little...
Roy, I'll call in for you...:rolleyes:
Hang on Sloopy...
David those are ATV tires of course, and they sure don't look worn out; either a tiny puncture like a rose thorn or I bet you've got a bad valve stem or tube. Any bubbles if you put water on stem? Might as well eliminate the easiest solution first...
Buppies, I'd come help you but I'd likely fall off the paver. Though I bet I could steer straighter than the guy who did my driveway.
do you provide Senior Care and Geritol at lunch? :D
   / Good morning!!!! #43,462
Pattern has flip flopped warm east cold stormy west but with heat in the east any front that comes through gives chances for strong thunderstorms
   / Good morning!!!! #43,463
53 going to 80.
Early county meeting this morning, then gym while in town, and maybe pick up a load of crusher run for driveway repairs where constant wet winter weather took its toll...and another chance to use new rake. :)
   / Good morning!!!! #43,464
53 going to 80.
Now I know I'm going to glow green with envy but Billie what do you pick up the crusher run with? A tilt trailer? If so, does it tilt high enough so all the stone comes out?
Or do you have a dump truck...
It's finally dry enough here to get trucks in, quite a switch.
   / Good morning!!!! #43,465
Drinking first cup of coffee. 54° with clear skies this morning . Heading to 78° with sunny skies. Bike ride today with neighbors. That should be enough for the day.
Good Morning All.
   / Good morning!!!! #43,466
64 this morning and headed to 73 today. Rain on its way.
Plans for today. Ummmmm. Let's see how much rain I get. But do have birds to take care of and of course check on cows.
   / Good morning!!!! #43,467
64° going to upper 70's today, low 80's tomorrow! :D:D:D
Sodamo, those are about normal for non golf course, golf cart tires, everyone has a lift kit nowadays.
My clam shell driveway is 4 years old this month, hard packed and slick with very little loose shell, if I could teach people to read so they don't miss their turn and use my shiny white driveway to turn around in at wide open throttle, the end would be nice too. But they keep tiny little pot holes going, especially when it rains. Just at the very end next to the road. 180' x 16' with 2 double turnouts and it all stays nice with just minor redress every couple of years except the end. I'm hoping we're due for a repave soon, a good friend of mine is the
State Highway Administration District Engineer, I think I can persuade him to make a nice apron in my drive, like they did at the old house, but it had an asphalt drive. Oh well, it's seat time.
   / Good morning!!!! #43,468
Good Morning. 0825, sunny, 69F with 70% humidity. Forecast high of 77F with no chance of rain today, and a low of 59F tonight. Today is my usual house cleaning day, but the garden and having to go in to work to finish the cleanup kept me from doing the shopping yesterday, so I'm going to try to squeeze that in sometime today. I hate it when my schedule gets de-railed.
You guys have a good one,
Larro
   / Good morning!!!! #43,469
Probably should have mentioned, these aren't the usual golf cart tires.
If this doesn't hold, will likely look for a tube.
I have used the Walmart aerosol type before, but was in HD so thought I would try the Tire Science.
David,
The aerosol type is not near as good. I had the same problem with the tires leaking because of thorns. Once I put the Slime in I have not had a leak in eight years. But I could use a new set of tires now, They are worn out. You have the same tires my neighbor Jim has on his Polaris 6x6 front axle.
59 and heading to 60. Cloudy.
   / Good morning!!!! #43,470
Good morning! Well not really, had a rude awakening at 5am VFD pager went off - structure fire. I'm getting too old for this. Turned out to be a small log cabin office behind a residence, and it was very hard to extinguish the large logs. The owner heard the lighting strikes about 3 hours before he noticed the outbuilding fire - it really had a good head start. It's still standing but the floor is burned out and every log is burned.
61˚ 1.5" rain as the storm passed through last night. It is still thundering but the rain is holding off.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
1996 Ford F-350 4x4 Flatbed Truck, VIN # 2FDKF38G8TLA64077 (A57453)
1996 Ford F-350...
Pair of 2001XA800Z Yamaha Jet Skis (A57453)
Pair of 2001XA800Z...
2013 Hyundai Veloster Hatchback (A56859)
2013 Hyundai...
Brent 420 Grain Cart (A56436)
Brent 420 Grain...
(8) Ten Hole 23 Inch Steel Rims (A57454)
(8) Ten Hole 23...
