Watch out - L2800 hose to cooler came off...
   / Watch out - L2800 hose to cooler came off...
I'm pretty certain that clamp didn't come on that machine from Kubota. They use wire type hose clamps or tension clamps, not worm screw clamps.
Brian
{Edit: HST ONLY might have this problem...}
#90 BAND, PIPE (red circle) #66204-36280 $7.89 5-7 business days
I guess these L Standard tractors were really "Economy" tractors....
Close up...
   / Watch out - L2800 hose to cooler came off... #12
Thanks for posting this teg. Just checked mine and like yours, it had dirt stuck there. I gave the clamp screw two full turns. That is the factory clamp since I got mine brand new and have never had this worked on. Just like the drawing you posted.
I also tightened the clamps on the other side of the cooler. The clamps on the cooler were both fine but the clamps on the other end were both loose.
Thanks for posting this teg...
No problem... Just wished someone did it before I lost 5 gallons :D :laughing: It's definitely some thing I would not have checked. The other clamps were very tight, could not tighten them any more. {edit: HST only}
I don't think there is a lot of pressure going through this cooler... Not sure what's the pressure.
   / Watch out - L2800 hose to cooler came off... #14
I didn't take any guards off or plastic, but I don't have anything on my l3400 that looks like that near the SN placard. HST thing only?
Good catch LD1, I didn't notice that.... "H24500 OIL COOLER [HST TYPE]" {HST only, might have this}
So gear models need not to worry about this... :ashamed:
   / Watch out - L2800 hose to cooler came off... #16
Just a heads up, it is a Kubota clamp or should I say clamps since there are four of them (you can see all of them on Tegs diagram, ccsial found them). One on each side of the cooler behind the nose plastic and one on each side where the rubber line goes to the hard line(Tegs Picture).
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2011 BMW 328xi AWD Sedan (A51694)
2011 BMW 328xi AWD...
BESTWAY AG VSK50 LOT NUMBER 103 (A53084)
BESTWAY AG VSK50...
2018 John Deere 8270R MFWD Tractor (A53342)
2018 John Deere...
2020 Ford F-350 Pickup Truck, VIN # 1FTBF3A68LEC75327 (A51572)
2020 Ford F-350...
2018 Ford Transit 250 Cargo Van (A51692)
2018 Ford Transit...
