Buying a snow blower for a john deere 110 backhoe
   / Buying a snow blower for a john deere 110 backhoe #1
LANGFORD
Burks Falls, Ontario, Canada
110 John Deere TLB
I have a new to me 2003 110 John Deere Backhoe
Was thinking of getting Pto snow blower
Any thoughts on what I should get.
Size, Name brand, What to look for in buying a used one
thanks
   / Buying a snow blower for a john deere 110 backhoe #2
Couple of things to look for:
* Impeller fan diameter - Bigger is better (bigger means faster tip speed which means less clogging and the snow is thrown further
* Number of impeller blades - More is better
* Ease of replacing shearbolts - If you have to take off 3 covers or don't have room to tap out a broken shearbolt you will be unhappy with it
* A power rotating chute and tilting deflector are much more convenient than their manual counterparts.
Aaron Z
   / Buying a snow blower for a john deere 110 backhoe #3
If me, I'd put a blade on the front.
   / Buying a snow blower for a john deere 110 backhoe #4
I've had a 60" Lucknow on the 3320 with good results for the last several years. I don't recall the specific HP of the 110, but you should be able to handle 72" - 84" range for most snow in your area. Have not had specific experience with other brands. You should be able to find a good Lucknow or Agrotrend on Kijiji at a decent price.
IMO Power Chute is a must. Deflector - I have not changed position of mine since acquisition, but have mostly open space to blow the snow.
   / Buying a snow blower for a john deere 110 backhoe #5
I have a new to me 1993 110 John Deere Backhoe
thanks
I think 2000 was the earliest 110tlb made so your tractor is newer than you think. I would go with a 7' rear blower for a little clearance. You have 33pto hp and a hydro so you should be fine.
   / Buying a snow blower for a john deere 110 backhoe #6
If you go with a 7' blower, make sure you have plenty of weight up front.
We have a 7' blower on our Kubota L3830 and when its on the 3 point, it makes the nose really light (to the point where you have to use split brakes to steer).
However, we don't have a loader on it, so with a heavy loader on the front you could be ok.
Aaron Z
   / Buying a snow blower for a john deere 110 backhoe #8
Aaron Z
When the OP removes the 1700 lb backhoe and switches to the blower he should be fine. The 110 has a fixed loader with ssqa bucket mount.
   / Buying a snow blower for a john deere 110 backhoe #10
billstmaxx had an interesting video about his JD 110 TLB. He had a snow blower on his fel. I know this is not what you want, I just found the video interesting.
New Long Forks (A53002)
New Long Forks...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT6DH646717 (A51572)
2013 Dodge Charger...
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
NEW Wolverine Skid Steer Trencher (A53002)
NEW Wolverine Skid...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
