GC 1710 / 1720 ROPS Roll Bar Angle Modification
   / GC 1710 / 1720 ROPS Roll Bar Angle Modification #1
fxdb96
SEBAGO
Massey Ferguson
Safety police - please go easy on me. Here is how I angled my roll bar so I can fit through my garage door. Also - I installed o-rings behind the 2 shoulder bolts / hinge bolts which are the pivot for the ROPS..... They rattled...
   / GC 1710 / 1720 ROPS Roll Bar Angle Modification #2
Cool idea but whats the big deal off taking off the bolts and lowering the rops down and the reinstalling them? Your only in and out of your garage once when u leave and once when u enter.
It's not that hard to take me off now.
Because there will be a day when the phone rings or i get distracted and forget to lower it and drive through the roof. Or someone else will jump on and do it for me haha.
   / GC 1710 / 1720 ROPS Roll Bar Angle Modification #4
The main problem I see is that those links are only going to handle a load in tension. Compression or side force will likely buckle them. Whether that hurts the effectiveness of the ROPS is the real question.
   / GC 1710 / 1720 ROPS Roll Bar Angle Modification #5
I agree . . . It seems the photo shows the integrity of the original design is substantially weakened when pressure comes from various directions. In effect this becomes your rops . . Not MF's engineered design. As a result if you are injured in a roll over . . you would have no claim against MF. It also might influence your own insurance carrier on injury issues. Lastly, I'm guessing your dealer would want a liability waiver signed by you . . if they see it . . As the owner of the dealership doesn't want to lose his house from your modification.
I'm not sayinf you can't do it . . Its just important to understand that there are consequences to it . . Modifying a government mandated safety device is much different than not wearing a seat belt.
   / GC 1710 / 1720 ROPS Roll Bar Angle Modification #6
I see no problem with modifying ROPS as long as it's done well. It is always at your own risk. Suggest OP improves his design.
Agree with others that the link is a weak point in compression (flipping over backwards) or from lateral forces in a side roll. At a minimum I'd add a second link to the other side of the tab. However I'd rather see square tubing of the same thickness. Tubing will better handle forces from all directions. However, just angling the upper ROPS will change forces on the lower ROPS. Without re-engineering the entire ROPS, there will always be risks to simple changes that impact the rest of the system.
My ROPS are cut, lowered and angled. But it was done as part of a larger system that far exceeds the function of the original ROPS for any senario I can think of.
   / GC 1710 / 1720 ROPS Roll Bar Angle Modification #7
How about putting a sign in front pf the garge that say.
STOP PUT ROPS DOWN BEFORE YOU ENTER :)
I did not think of that - thats a great idea
   / GC 1710 / 1720 ROPS Roll Bar Angle Modification #9
Looks like you've done a nice looking job with your rops. I like the Ford in the picture better though.:D
Yahh red is my color if u didnt notice haha. My 2013 f150 is red too!
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
Pallet of Drain Grates (A56469)
Pallet of Drain...
Mohawk TP-15 15,000lb Two Post Auto Lift (A55852)
Mohawk TP-15...
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A55852)
2020 Ram 1500...
2016 John Deere 5055E 55HP Utility Tractor (A55973)
2016 John Deere...
