Creamer
Elite Member
I used to use the bar length as a gauge. Since I mostly use 16" bars, and I like 16-17" logs, it was a nice match. However, turning the saw to measure got old.
Then I was shown a nice gizmo by an old timer: Bent a piece of stiff wire (a coat hanger will work) into an L shape. The short leg is only 1 to 1.5" long. Use 2 zip ties to attach it to the lower left end of your front handle. (I have the short leg pointed down along the handle, and the long leg poking off just above where the handle curved to go under the body of the saw. I put a hook in the end of the short leg and crimped it over to keep it from sliding out from under the zip tie.) Swing the long leg of the wire out perpendicular to the bar. For a 16" log, trim it so the distance from the bar where it meets the saw to the end of the wire is 16" (the wire itself is a good bit less than 16", since the handle is already 6"+ away from the bar at this point). When you want to cut 16" logs, swing the wire out perpendicular to the bar and use it as a gauge for log length. When not in use, you can flip the wire in, along the side of the saw pointing rearwards. Mine stays right along the side of the saw, out of the way when not in use (I tied the short leg of the L to the inside of the handle, so that it will lay flatter against the side of the saw)
A couple of tweaks to the design:
1) If you cut the long leg a bit longer than you need, you can fold the end over to the length you want, then tape it up. This makes the end of the wire less of a "poke hazard".
2) with the right zig-zags bent into the short leg, and the right tension on the zip ties, you can make a sort of "detent" that will help hold the wire either out at 90˚ or flat in against the saw body.
If I remember, I'll try to post a picture. It's simpler than it sounds.
I think I have it but a photo would be great!
