4600 ford tractor
   / 4600 ford tractor #1
sirfixalot
Blountville, tn
ford 4600
I have a 4600 ford diesel tractor gaining oil. It's not colored,muddy, smells like diesel. I've been told that i have a fuel injector leaking. is there anything else could cause that to happen.
   / 4600 ford tractor #2
Could be the fuel lift pump. If the diaphram has a hole in it fuel can leak past the pump directly into the base.
   / 4600 ford tractor #3
No lift pump on a 4600. Could be a fuel injector, injector pump shaft seals, or less likely a failed thermostart unit. Could also be a failed power steering pump, but that would not smell like diesel.
2007 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XL...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2011 JACK 130BBL (A53843)
2011 JACK 130BBL...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
