I have these good for nothing Basswood's and have been getting rid of them "releasing" better species for growth. A "corduroy" road through some wet areas is about the only thing I do with them. I haul them in on the log trailer.
There is a "bottom" in that wet area, and the tractor will go through it but now you can walk it without rubber boots. Today I finished the last 12' or so after starting it last year.
I like your corduroy Rusty :thumbsup:
I never realized what poor firewood basswood made until I tried burning a big one that the power company cut down. Thought I was in hog heaven with all that easy wood. Yikes. If it's not a saw log a corduroy road is perfect use for it.
gg
How does basswood compare to something like poplar for building material? I have several I could use for interior barn beams, if they would be worth using.
So here are some pictures of my coat-hanger chainsaw firewood gauge. I don't use it for every cut, but it does come in handy when first starting out, or when I switch form one diameter log to another and need to recalibrate my eyeballs. Hope this helps.
View attachment 461576View attachment 461577View attachment 461578
If I'm standing on the wrong side of the log, so the wire is pointing in the direction away from the log end, I just look where the end of the wire is while finishing up a cut, and that's where I move the saw to for my next cut. If I've already moved, rather than moving back to measure, I just eyeball that the distance from the tip of the wire to the bar is the same as the distance from the bar to the end of the log. It still comes out close enough. You;ve got something close by for scale, and it's pretty easy to position for the midpoint between the wire tip and the log end. (I hope that description made sense).
Selling it, is a whooooole lot different, than like the "mass majority" on here, who like me, just burn it!
I've never owned a wood stove yet, that gave a dam what the firewood going in it, looked like!
SR
Off topic question about your post. What program are you using to add text to your photos.
