GFCI lifespan only 10 years?
   / GFCI lifespan only 10 years? #11
As GregbkH states, technology changes daily that sometimes makes our lives safer (sometimes not so much) so building Code requirements change to include new technology. However many of the changes in the Code are done to correct a mistake that cost someone their life. The same thing happens with the OSHA safety regulations, a change is usually the result of some persons unfortunate death.
In aerospace engineering where I worked for 32 years, this is called tombstone engineering.
   / GFCI lifespan only 10 years? #12
Maybe I'm a bit jaded over the years, but I view the GFCI changeout issue the same as kids car seats. I got "educated" this weekend by my daughter-in-law that my grandchild's car seat was going to expire in 2 months and I had better buy a new one! Is this stuff for real? How does a car seat expire? Or why does a refrigerator now only have a live expectancy of less than 12 years?
   / GFCI lifespan only 10 years? #13
Planned obselescence...
why sell one when you can sell 3 over time.
As for companies driving code requirements.. it happenens everywhere.
Any anyone who doesn't think there is a financial angle to the argument is lieing or just doesn't want to know.... ;)
   / GFCI lifespan only 10 years? #14
I have a hospital full of Hubbel Hospital Spec GFCI dating from 1995 and not once has a single one failed testing.
Also have some Hubbel non Hospital Spec and no problems either.
Wish I could say the same for the contractor packs I bought at Home Depot 15 years ago... don't know the number but a lot have failed... most stop by not being able to reset and a few will not trip.
My impression is you get what you pay for.
   / GFCI lifespan only 10 years? #15
Odd how some things don't last as long as they used to, but others last way longer. For example, when I was a kid, getting 125k miles on a car was good. By then serious rust and the rings were toast. Now days, over 200k miles is expected.
As far as a GFCI, I would think it's more of a number of trips that determines end of life. Or heavy loads. I had GFCI's in a seldom used bath for 20 years. I tried using one in a home made extension cord splitter for a safer work site. Burned up in a week!
I also have been chairmen for a NEMA standards committee, all manufactures. NEMA = National Electrcal Manufactures ***. All members are representing manufactures. We write the standards because we know the products better than most anyone. We lso know the weaknesses and limitations of a product. This is often the basis for Type, Sample and Routine testing. Recently the NEC contacted NEMA to "push" application limits. We refused because we know the limits.
So when I see packages stating "life expectancy", I take it with a grain of salt. Like change your smoke detector batteries twice a year even though they have a 5 year shelf life!
A bigger concern of mine is old receptacles a switches. You know the receptacles where the male plug just goes in with hardly a push, or worse, falls out! Switches buzzing. Only device to protect are arc-fault breakers
   / GFCI lifespan only 10 years? #16
I've had some "fail" in less that 4 years (good pricey ones at that). Never know why, they just "fail" (and I think the newer ones are engineered to fail in the "dead" position...you don't lose the GFCI protection, you lose it all). I personally don't agree with much of the current code ("arc-fault"??? "tamper resistant"??? even GFCI in many areas)...but that's the way things are. I keep a stock of stuff for replacements...
   / GFCI lifespan only 10 years? #17
If the OP thinks that 10 years is bad wait till he buys the new outlets. UL has changed how they work now they are self testing. They are self testing and like anything new won't last a year till they break. Like the first AFI breakers until they got to the third version they were junk.
I've tried my GFI tester in the new gfi's and it won't trip I'm told they don't make a tester yet. " The inspectors are going to love it.."
New Standard for GFCI | UL 943 GFCI Standard | by Legrand
   / GFCI lifespan only 10 years? #18
The more technology added the more prone to failure. The sad part is someone's home life support may depend on this new stuff to work and it fails and leaves them in a bad state. The old outlets lasted for decades. Now a unknown life span will have to be relied on.
   / GFCI lifespan only 10 years? #19
Punish the masses for the sins of a few (kinda like gun control ain't it)? My MIL bought an 80's house recently...the outlets/switches "bothered me" (painted over, etc.). When I built this house I used quality stuff (Pass & Seymour). Tried to find them again and the prices had tripled in just a few years. You can't buy an outlet now without "tamper resistant". Arc fault is a joke. GFCI...getting worse. I have to wonder how many lives we save (forget about Darwin) and at what cost.
   / GFCI lifespan only 10 years? #20
Me too. Every plane crash usually results in updated or new regulations. Lessons learned the hard way.
2009 FREIGHTLINER BUSINESS CLASS M2 CRANE/POLE TRUCK (A51406)
2009 FREIGHTLINER...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
