Price for BCS 605 with Tiller
   / Price for BCS 605 with Tiller #1
Ford850
Super Member
Ohio
Case DX55, Ford 850
I'm thinking about selling my BCS 605 with 30" tiller, to get a new 853. My main reason is to get the transport speed from the 853, since I use a sulky and/or trailer quite a bit.
What would be an average selling price for the 605 with tiller? It has the 12.5 v-twin vanguard engine that starts easy and runs smooth. It was ordered in early 1995, labeled as a 605, but shipped with an 850 manual. One of the last 605's, with the same features as an 850. It has 5x10x20 wheels in very good shape. I replaced the bearings, seals, and tines on the tiller a year ago. It's always been stored indoors so there is no fading, etc, but there is minimal rust starting on the wheels. It's never been used as a mower so the hours are relatively low while working (tiller and snow blower use), and then light use hours for sulky and trailer use.
What is your best guestimate on a reasonable selling price?
Any guestimates?
Thanks Brad, that puts the value around $2250 which would be great. I was thinking in the range of $1700 to $2200.
   / Price for BCS 605 with Tiller #5
This time of year, you might get that. But, the 605 is 3 generations old, and still has the spline PTO. In my opinion, that doesn't lower the usefulness of the 605, but it does require that any new attachments be ordered with spline PTO, or an adapter has to be bought. This will affect value.
I'd say $1500 to sell it fast up to $2200 to get maximum value.
It doesn't have the spline PTO. Being one of the later 605's, it's basically an 850. It has all the features of an 850, but it's a 605. But your price range is what I'll shoot for if/when I sell it.
   / Price for BCS 605 with Tiller #7
If it's a 605, it has a spline PTO. They never made a 605 without one that I am aware of. The late ones also had a flat 3 dog engagement, but it was still spline PTO, and nothing like an 850's engagement. The 850's engagement was all internal, the 605 and earlier model's engagement was external. Take the tiller off and engage the PTO. If you see the PTO slide out, it's splined with flat 3 dog. You can't use it with modern tapered 3 dog PTO equipment without an adapter. If you don't see anything slide out, then you either have something I've never seen, or you have a mis-labeled 850.
Another difference is in the shifter quadrant. 605s have straight through shifting, 850's have stops at every gear, so you need to move the shifter side-to-side while shifting.
On a side note, I did see a 605 a while back that the dealer sold as an 850. The owner had the original bill of sale that stated it was a 1995 850, but the machine was clearly a 605. I'm guessing he had old inventory, and wanted to dump it. The owner was pretty disappointed to find out that he paid new price for old inventory...
Great info FBB. I bought mine in early 1995 but I don't remember if I thought I was getting a 605 or an 850. I remember when it came in, the dealer said BCS was changing models and numbers, and that was the reason it came with an 850 owners manual but the tractor was a 605. The manual is titled "New Series 1994 Owners use and Care Manual". It describes the use and set up for the 830 and 850, and shows the straight shifter in the diagram (like mine has too). I still have the BCS sales catalogue/brochure from when I bought it, and it lists the "Professional 605/850". It came with a "free" tapered 3 dog quick coupling like they do yet today. It has the quick coupling on the tractor, paired with the tapered 3 dog male ends on the tiller and snow blower. I assumed the tractor was tapered 3 dog too, but I just checked like you said above and it is the flat 3 dog. I've been using it that way, pairing the flat 3 dog from the tractor to the tapered male ends on the tiller and snow blower for over 20 years, and never had any problems. The connections are still very tight with no wear.
I always thought of it as an 850 because of the manual and brochure I guess. That might explain how the other guy you referenced above thought he bought an 850 too. I used to think mine was sort of a hybrid as it was built in the transition year. But now I think it might be a mutt instead. :)
   / Price for BCS 605 with Tiller #9
I don't think flat 3 dogs fit with tapered 3 dog. The flat 3 dogs physically move out to engage the attachment. The tapered 3 dogs work internally to engage the attachment - the dogs don't move out. You must have an adapter in the somewhere. Could you post a picture?
I took a few pictures. PTO disengaged, engaged (these are looking in through female coupler), and the male coupler on the snow blower. I can see some wear on the leading edges of the tractor's dogs from the tapered dogs on the couplers.
   / Price for BCS 605 with Tiller #11
That's a new one on me. I never would have thought you could run flat with tapered. I don't think you're supposed to.
I don't think your 605 is a mutt. It's a normal late model 605.
I appreciate your feedback on this. I never realized mine was not a tapered 3 dog PTO until I cleaned the grease off to take pictures today. Is the internal PTO engagement of the 850 and newer tractors better than the old spline style?
   / Price for BCS 605 with Tiller #13
The tapered 3 dog PTO is a little bit stronger, but the external spline / flat 3 dog PTO is easier to fix if something goes wrong. Grillo still uses the same internal spline PTO that both BCS and Grillo used all the way back in the 70's. It's a perfectly fine system for many attachments, but it's not as robust for the largest and most power hungry attachments that have come out in recent years. The Grillo G110 introduced last year has a stronger PTO to accommodate these attachments.
FBB, I know you've used a variety of wheel/tire sizes over the years. Are the larger 22 or 23" tires acceptable for tilling and snowblower work?
   / Price for BCS 605 with Tiller #15
Larger tires hurt the tiller when used for breaking ground. With stock tires, the tine turn 20 times per tire rotation. Bigger tires increases ground speed, which lessens the ratio. They also changes the angle of attack, which increases the amount the engine tips, possibly causing trouble for a splash lube engine. I don't know of any engines that have blown up because of this. Pressure lubed engines have more tolerance, but I am not aware of a pressure lube engine available for a BCS right now (except diesels). Your V-twin might be pressure lubed - Does it have a filter?
They seem to be fine for snowblower work as well as most other attachments.
My V-twin isn't pressure lubed. I wonder if the Subaru Robin engines that Joel offers are any better design for lubing compared to the stock Honda's. I know they are OHC instead of OHV but I don't know which, if either, have a lube advantage.
   / Price for BCS 605 with Tiller #17
That is interesting. Looks like you have one of the old (no longer made) quick hitch to fit the 605/737 with combo spline/flat 3 jaw PTO, but it has tapered 3 jaw PTO. I wonder if someone just swapped the PTO "connection" on that quick hitch from flat 3 jaw to the tapered 3 jaw. Seems weird that set it up that way. Anyway, yes, the 737/605 come with the combo spline/flat 3 jaw PTO, prior to the new tapered 3 jaw PTO that came out in 1995. So your 605 is a pre 1995, but probably early 90s model. Since 1995, most of the PTO is now enclosed in the transmission and in oil bath. This is definitely a better setup as everything except the 3 teeth are inside the transmission in oil bath. Grillo still uses this old style. It works fine. I run both. My Grillo G131 has flat 3 jaw PTO. But if I can have my wear components in oil bath instead of grease I would rather do that. Of course putting the transmission back together is more difficult now that everything is inside the transmission on the BCS.
As to taller tires and tilling, yes it does change the angle. Another thing is if user is very tall (over 6' 4"), it might be difficult for them having to lean over (more back aches), especially on Grillo since they only have 4 handlebar height adjustment positions. If user only tills, makes sense to use 5" x 10" maybe. But I do so much with my BCS/Grillo machines that I would never run less than 5" x 12" except in extreme cases.
I guess it was in the transition period ('94 - '95, 605 - 850). Like I said above, my dealer ordered it for me in early '95. It came in labeled as a 605, but with a "New for 1994" owners manual for 830/850's. No mention in that manual of a 605. It also came shipped with that tapered 3-dog quick coupler.
That's a good point about the handle height while tilling. I'm 6' 4"-ish, but my 605 has no issue getting a tall handle setting with the 5-10 wheels. Taller wheels will make for lower handles. My tilling use is mush less than it used to be though, since I mainly break ground with a larger 3ph tiller now. It gets used mostly with a sulky and wagon, or a trailer.
Thanks again for the feedback.
   / Price for BCS 605 with Tiller #19
That's not the old style quick coupler. The old style didn't have a tapered tang.
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2019 Yongfu Scooter (A59231)
2019 Yongfu...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
20800 (A56859)
20800 (A56859)
2008 Freightliner Allegro Bay Class A Motorhome (A59231)
2008 Freightliner...
PALLET OF (3) INDOOR CABINETS (A60432)
PALLET OF (3)...
