Need help with a 16HP Kohler 2 cylinder engine
   / Need help with a 16HP Kohler 2 cylinder engine #1
travlitt
Texas
8050C Branson, Branson 2400, 8N Ford, Round Fender John Deere 110, 3 60" ZTR mowers, a bunch of ride on mowers, 8' Brush hog , 15' Bat wing
I have a 16HP kohler 2 cylinder engine that runs on one cylinder. It has new plugs. Both cylinders fire when they supposed to. 1 cylinder makes power and the other one does not make more than 25% power. I checked the compresson on both cylinders and both of them have 120 PSI and will hold that pressure without leaking down. I can pull either plug wire off and there is lots of sparks on either plug.
I removed the double inlet muffler and the one cylinder has a lot of exhaust pressure and the other one has some but not much. Then from time to time the week cylinder will start making power at or near 100% but not full time.
What might the problem be?
   / Need help with a 16HP Kohler 2 cylinder engine #2
Valve not seating properly?
   / Need help with a 16HP Kohler 2 cylinder engine #3
Check compression
Head gaskets in particular are a weak point.
The 23HP Kohler in the Bolens just got done with the same "symptom" as you describe.
Not an easy task, as the engine must come out, and then while it's out the rings, and valves get a "freshening".
Check compression
120# of compression on each cylinder and both will hold the pressure.
   / Need help with a 16HP Kohler 2 cylinder engine #5
I've read of issues with the cam gear on some Kohlers, but if both cylinders have equal comp, and one of them always runs well,with the other sort of "hit or miss", I suspect an ignition trouble. What engine are you discussing?
Swap plugs wires etc. one by one, and see if the trouble follows. Run the engine in the dark to see if the high tension spark is leaking anywhere. Does the governor have points?
Follow up on the problem I had with the 16 hp Kohler engine.
It is the engine with the overhead cams that are belt driven. The problem was most of the teeth on the bank that was not making power were worn almost down smooth and the belt had too much slack in it. This condition caused the one side to jump time therefore it was not fireing on the compression stroke at the correct time.
Thanks for all of the imput from each of you.
2019 KENWORTH T800 (A53843)
2019 KENWORTH T800...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53473)
2-Row Peanut...
MISC WRENCHES (A53843)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
