Trouble filling DEF at Truck Stop?
   / Trouble filling DEF at Truck Stop? #11
We have tried 180 degrees, will have to try 90 degrees, it is a super annoying problem.
There is a TSB (Technical Service Bulletin) on this issue. It is possibly related to operating in a dusty environment and required the replacement of the carbon canisters and vent tube. You can check with your dealer and tell them about TSB 12-2-14.
FORD: 2005-2012 F-250, F-350
This article supersedes TSB 11-4-3 to update the vehicle model years, Issue Statement and Part List.
ISSUE:
Some 2005-2012 F-Super Duty 250-350 vehicles equipped with a 5.4L 3V, 6.2L or 6.8L 3V engine may experience premature automatic shut off of the fuel fill nozzle. This may include box delete vehicles that have been upfitted with aftermarket utility bodies or vehicles that are operated in muddy or dusty environments and may encounter a dirt clogged carbon canister system.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
NOTE: THIS PROCEDURE ONLY APPLIES TO F-250-350 PICKUPS AND F-250-350 PICKUP BOX DELETE VEHICLES WITH GAS ENGINES.
Inspect the vehicle's canister system.
If the canister system is not dirt clogged and the vehicle is an F-250-350 pickup, then proceed with normal diagnostics and do not continue with this procedure.
If the canister system is not dirt clogged and the vehicle is a box delete, then replace the filler pipe (box delete vehicles only).
The new filler pipe should only be used for box delete vehicles that are exhibiting slow fill issues due to the aftermarket routing of the filler pipe with the upfitter's box. The new filler pipe kit provides additional design measures to improve the ability to fill the vehicle.
If the canister system is found to be dirt clogged, then continue with Step 2.
Replace the carbon canister assembly per Workshop (WSM), Section 303-13.
Relocate the fresh-air intake port to a more protected location using a new fresh air hose kit.
Replace fuel cap assembly.
Replace the fuel filler pipe only on box delete vehicles that have been upfitted with aftermarket utility bodies.
NOTE: WARRANTY COVERAGE IS NOT APPLICABLE ON VEHICLES IF THE BOX DELETE FILLER PIPE HAS BEEN MODIFIED FROM THE INITIAL FILLER KIT TO MEET UNIQUE AFTERMARKET/BODY BUILDER INSTALLATION.
PART NUMBER PART NAME
9C3Z-9049-A Vent Kit
6C3Z-9D653-F Canister (Pickup 2005-2007)
9C3Z-9D653-C Canister (Pickup 2008-2012)
8C3Z-9030-A Fuel Cap Assembly (2005-2010)
AC3Z-9030-A Fuel Cap Assembly (2011-2012)
8C3Z-9B149-L Filler Pipe (Box Delete 2005-2010)
BC3Z-9B149-G Filler Pipe (Box Delete 2011-2012)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
120214A 2005-2012 F-Super Duty 250-350 5.4L/6.2L/6.8L With Pickup Box: Inspect The Vehicle Canister System, Replace The Charcoal Canister, Install Fresh Air Inlet Kit, And The Fuel Cap Assembly 1.5 Hrs.
120214B 2005-2012 F-Super Duty 250-350 5.4L/6.2L/6.8L With Pickup Box Delete: Inspect The Vehicle Canister System, Install Filler Pipe Kit 0.9 Hr.
120214C 2005-2012 F-Super Duty 250-350 5.4L/6.2L/6.8L With Pickup Box Delete: Inspect The Vehicle Canister System, Replace The Charcoal Canister, Install Filler Pipe Kit 1.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
9E857 42
   / Trouble filling DEF at Truck Stop? #12
Busted for not reading the OP's post or thread. His issue is with pump filling the DEF tank on his Powerstroke Diesel.
   / Trouble filling DEF at Truck Stop? #13
But then there's this (which is what I assume the TSB refers to):
Sorry to hear about your troubles, it can be a pain, Our 2009 Ford F350 6.8L V10 has thatt same issue when filling up the gas tank, it takes half an hour to fill it up.... :(
   / Trouble filling DEF at Truck Stop? #14
You have a problem with the vent pipe not letting air go out so fuel can go in.
   / Trouble filling DEF at Truck Stop? #15
I'm loving my old 2001.5 Dodge Cummins H.O. 6spd more and more each day..... even with it's own set of warts and shortCummins.... :)
   / Trouble filling DEF at Truck Stop? #16
ISSUE:
ACTION:
SERVICE PROCEDURE
WARRANTY STATUS:
DEALER CODING
9E857 42
Thanks for the info...
   / Trouble filling DEF at Truck Stop? #17
Thought I dodged the bullet getting my old tier 2 tractor in the nick of time; only to find out the used diesel truck market took off in response to these changes too.
Maybe our next administration will reverse some of this nonsense.
   / Trouble filling DEF at Truck Stop? #18
So after all these years, that cartoon of the boy peeing on the fords and chevys has become a govt regulation. Too funny...
   / Trouble filling DEF at Truck Stop? #19
And it's a 5 gallon tank. Drink up, boys.
This also makes the under-hood fill location a bit akward.
   / Trouble filling DEF at Truck Stop? #20
Is your f350 a cab chassis? If so who mounts the filler into flat bad is not Ford and there could be part of the issue?
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A56129)
2007 POWERSCREEN...
2020 Kubota R530 (A53314)
2020 Kubota R530...
Giyi Hydro Pallet Forks (A53316)
Giyi Hydro Pallet...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A55788)
2006 Chevrolet...
1995 PETERBILT 377 TRI  AXLE DUMP TRUCK (A56129)
1995 PETERBILT 377...
2012 Peterbilt 337 IMT 6025 14,000lb 5 Ton Crane Mechanics Truck (A55788)
2012 Peterbilt 337...
