Looking for a Harbor Freight Pump Gas Cap
   / Looking for a Harbor Freight Pump Gas Cap #1
Travelover
Elite Member
Washington
B7100
I've got a 3" gas water pump from Harbor Freight. Unfortunately, the gas cap vibrated off and landed on the engine. I arrived to find a melted plastic pancake. An email to HF was met with a "Sorry, parts no longer available" message.
The OD of the threads on the gas tank are about 2 1/4". A generic 2 1/8" cap sold at places like Home Depot is too small.
Any bright ideas on where to look for a cap or ideas to make one out of common materials? :confused3:
   / Looking for a Harbor Freight Pump Gas Cap #4
I recently purchased a 3" trash pump and it also has a threaded cap and a separate tank vent with a hose going to the carb or air cleaner. Must be EPA mandated. Not sure if mine has male or female threads.
I was looking for a replacement cap to modify like they do to get extended run times on Honda generators. This pump does have a fuel pump so I might just slip a fuel line into a gas jug and bypass the built in tank. Might be a temp option for you.
   / Looking for a Harbor Freight Pump Gas Cap #7
iu
   / Looking for a Harbor Freight Pump Gas Cap #8
That works, but they flare up, and taste bad when cooked, after you find your cap.
Bruce
   / Looking for a Harbor Freight Pump Gas Cap #9
maybe a 2-1/4 npt black iron pipe fitting ? or plastic/pvc npt fitting?
or even brass my bus uses one about 2-3" in dia
I recently purchased a 3" trash pump and it also has a threaded cap and a separate tank vent with a hose going to the carb or air cleaner. Must be EPA mandated. Not sure if mine has male or female threads. I was looking for a replacement cap to modify like they do to get extended run times on Honda generators. This pump does have a fuel pump so I might just slip a fuel line into a gas jug and bypass the built in tank. Might be a temp option for you.
This pump had a similar system and the pump would die unless I left the cap a little loose. That was why it vibrated loose and melted.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
UNUSED FUTURE FT13CJ EXCAVATOR (A51247)
UNUSED FUTURE...
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
