Anybody ever seen a zero turn with 33 grease zerks?
   / Anybody ever seen a zero turn with 33 grease zerks? #1
NoTrespassing
East Central Illinois
Kubota 1999 L3710 HST FWA
My 2000 Walker literally has 33 grease zerks and another 30 oil points that I hit every spring. The engineers at Walker love their lubricants. This is not an April fools joke btw. When I first started shopping for a zero turn 3 years ago I inquired about additional maintenance for a zero turn and was told it was about the same as a standard tractor style mower. I'm just guessing that Walker is not normal when it comes to lubrication.
Kevin
   / Anybody ever seen a zero turn with 33 grease zerks? #2
Wow, that's a lot. My front mount Grasshoppers have 10 grease points. 2 of those get greased every 40 hours, and another one at 80 hours, so not very often. The remaining 7 get greased every 8 hours of use.
   / Anybody ever seen a zero turn with 33 grease zerks? #3
My Grasshopper has 9 that I can think of, where is the 10th on yours?
(2 rear wheels, 2 pillow blocks on the shaft, 2 deck casters and 3 blade spindles).
   / Anybody ever seen a zero turn with 33 grease zerks? #4
1 on the drive shaft coupler under the foot rest.
   / Anybody ever seen a zero turn with 33 grease zerks? #5
Oh yeah that one on the drive half shaft.
It broke off before I owned it but the mower gets uncoupled every year and that half shaft greased anyway. The release coupler gave up releasing a long time ago.
I use a blade on mine in the winter.
   / Anybody ever seen a zero turn with 33 grease zerks? #6
Lets see, my Ferris has 3 on the deck, 2 on the front wheels axle that I grease about 2-3 times per season when I grease the deck and 2 on the front wheel swivels that are greased once per year for 7 total. There are a couple of spots on the controls that call for spray lube which I do once a year.
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
2004 Sterling Tack Truck (A52384)
2004 Sterling Tack...
1065 (A53342)
1065 (A53342)
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2015 Chevrolet...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
