Power Reverser quick question. JD 5100e potential purchase
   / Power Reverser quick question. JD 5100e potential purchase
I drove a 5100M and the 5100e that I'm looking at this morning.
The abrupt shift in direction was noticed more in the very low gears compared to more normal 'working' gears. Both were similar, so I believe that the quick action is just how things work. I spoke with the Technician who works on them as well, and he said unless you have the option which allows you to adjust the speed of reversal, this is pretty standard and won't cause damage to the tractor or transmission.
Thanks for your input. I feel much better about it after hearing your experiences and checking it all out again.
   / Power Reverser quick question. JD 5100e potential purchase #13
I agree with the technian as long as it doesn't shift really hard its better on the clutch to execute a crisp shift as opposed to slipping particularly if the revs are high
   / Power Reverser quick question. JD 5100e potential purchase #14
There should be adjustment in how hard in shifts. They actually sell a kit where you can make changes to the shift speed on the fly.
Correct, there is a kit that you then can change fill pressure settings for forward and reverse. lvb25727 (verify this # based on unit s/n though) and is not terribly expensive. M series units would already have this feature std.
   / Power Reverser quick question. JD 5100e potential purchase #15
I'm buying an m series but don't recall it as standard feature but an option.
   / Power Reverser quick question. JD 5100e potential purchase #16
It's probably easier on the parts to throttle down before reversing direction. I always did that on the Cat D3 I had.
   / Power Reverser quick question. JD 5100e potential purchase #17
It was not std. on the 5065M but my wife and son them put it on there and no matter where you set it, you can't tell a spits worth of difference, I don't think the dealer programmed it properly. The direction change is very smooth in every gear I've tried but I rarely drive it so can't say about every speed or RPM setting. One strange thing I find is that the reverse speed is a tad faster in each gear than forward according to the manual.
   / Power Reverser quick question. JD 5100e potential purchase #18
Sorry, what I should have said is that it is standard for current production machines with the 32/16 tranny. Did not mean to mislead, it is not std for all transmissions.
   / Power Reverser quick question. JD 5100e potential purchase #19
On the 6430 it seems a bit jumpy but I'm still used to the clutch.
I once ran down the road at 25 mph and wanted to turn the signal on and put it in reverse instead. No difference in direction in that case. It killed the engine.
   / Power Reverser quick question. JD 5100e potential purchase #20
Well I didn't know that either. Thanks for the info.
(2) GOLF BAGS W/ CLUBS (A54757)
(2) GOLF BAGS W/...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2025 MS380R Mini Stand-On Track Loader Skid Steer (A56857)
2025 MS380R Mini...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
John Deere 5055E (A53317)
John Deere 5055E...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
