Stihl 051/075 ignition
   / Stihl 051/075 ignition #1
tuxy
Europe
VTZ
Hello everybody, i got this old stihl 051/75/76(not sure about the model) about month ago, in general chainsaw is in good shape consider how old it is, compression is good, crank bearings too, but my only problem is that it dont have spark, it have this coil that is really rare to find, coil has been tested and it is working great :) when i put it on saw sometimes it have tiny little spark sometimes not and only on cable, when i put sparkplug nothing, now i am not an expert in ignition and electronics so could someone just help me with this old beast :) :confused: untitled.JPG stihl-051-av-electronic-dijelovi-slika-43030620.jpg
   / Stihl 051/075 ignition #2
Hello everybody, i got this old stihl 051/75/76(not sure about the model) about month ago, in general chainsaw is in good shape consider how old it is, compression is good, crank bearings too, but my only problem is that it dont have spark, it have this coil that is really rare to find, coil has been tested and it is working great :) when i put it on saw sometimes it have tiny little spark sometimes not and only on cable, when i put sparkplug nothing, now i am not an expert in ignition and electronics so could someone just help me with this old beast :) :confused: <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=463877"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=463878"/>
Is it a new spark plug and do you have a good connection from the cable to the top of the plug? How are you grounding the plug when checking the spark?
spark plug is brand new, cable too, i put sparkplug on cylinder for grounding
   / Stihl 051/075 ignition #4
Go to this site and post your problem on it. These guys will not only be great help, but may also have the parts you need.
http://www.arboristsite.com/
   / Stihl 051/075 ignition #5
Points under the flywheel. It is a old saw.
2016 Nissan Sentra Sedan (A56859)
2016 Nissan Sentra...
Hydraulic Floor Jack (A59076)
Hydraulic Floor...
2008 Caterpillar G23G Scraper, S/N CAT0634GADBY00493, Cat Turbo Diesel, 12,763 Hours Indicated, (A59076)
2008 Caterpillar...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2198 (A58376)
2198 (A58376)
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59575)
2007 STERLING...
