Bundling cargo ratchet straps (method w/pics)
   / Bundling cargo ratchet straps (method w/pics) #1
Sodo
Elite Member
Cascade Mtns of WA state
Kubota B-series & Mini Excavator
Just figured out this method and made a pic for y'all. Not sure if it's better than the loose-knot method. Anyway, try this one and see if it helps to organize straps.
464321d1460389017-bundling-cargo-ratchet-straps-method-bundle_ratchet_straps-jpg
   / Bundling cargo ratchet straps (method w/pics) #3
Under DOT rules, those are illegal for lashing cargo that traverses public highways. having said that, I use them too, foe hauling hay bales. DOT regs require 4" wide straps now.
   / Bundling cargo ratchet straps (method w/pics) #4
I use straps like that for hay, too. Like other things near me like this (cords, hoses, straps, cables, wire), they attack my feet one leg at a time and eventually trip me up. I'll try your method. Looks useful.
   / Bundling cargo ratchet straps (method w/pics) #5
All the roll backs use cargo straps through the rims... none are 4" wide.
   / Bundling cargo ratchet straps (method w/pics) #6
I haven't ever seen a 4" ratchet strap except for those permanently mounted on a flat bed semi trailer. Four 2" straps have a combined safe working load limit greater than the axel capacity on my trailer. A single 2" strap has a working load equal to the axel capacity of my lawnmower trailer. A single 2" strap has working load rating much greater than the axel rating on my other single axel lawnmower trailer. It seems pretty stupid that I would need 4" straps.
   / Bundling cargo ratchet straps (method w/pics) #7
These are very popular on lumber racks - 1.5" straps.
   / Bundling cargo ratchet straps (method w/pics) #8
I have been using the rackit straps for 20+ years... work well and always where I need them.
   / Bundling cargo ratchet straps (method w/pics) #9
Can you show the regs for this? Last I looked, the only cargo that required a specific tiedown was crushed cars which required cables or chains (not straps or ropes)?
Everything else is based off of the WLL of the tiedown.
Aaron Z
   / Bundling cargo ratchet straps (method w/pics) #10
That sounds like a regulation for a specific type of cargo. Cargo is a broad term. I don't think the DOT cares if I use several 1" straps, or a couple 2" straps to tie a couch onto a landscape trailer for example. That's cargo, but 4" straps seem a little overkill in that instance.
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
greenworks (A53421)
greenworks (A53421)
2020 VANGUARD CIMC 53FT REEFER TRAILER (A54607)
2020 VANGUARD CIMC...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
