Good morning!!!!
   / Good morning!!!! #44,891
Schools have been closed, we are at 7.5" so far.
Just 20 miles south of us in Lagrange they are at 20.03" and still raining.
   / Good morning!!!! #44,892
That grapple looks great, Looking for the action video. Ed
Thanks ... I might see if I can persuade The Woman to come out and shoot some video today.
Nice job on your driveway ... and very nice looking home.
We always wanted a log home but never got around to making it happen.
   / Good morning!!!! #44,893
This has taken just 6 hours to go from nothing to 4' over flood stage.
   / Good morning!!!! #44,894
... RS, that grapple looks awesome.
Thanks ... :eek:
Looks like you've already had a little fun with it in the dirt.
Yeah ... I had tested the bottom root rake portion of it before I actually had the grapple done ... seemed to work pretty well.
Your thread on building it is quite informative.
Thanks ... I was hoping some might find it helpful.
Started working on adding on to my little post and beam tractor barn. Originally built it with no experience, drawing plans "on a napkin" 27 years ago as a goat barn, for storing hay, grain, room for a milking stand, plus built a feeding trough on one wall. Later converted it to use for horses, then most recently as a place to store garden tools and park my tractor. Never thought it would last this long. It is all board and batten from green pine cut at a nearly mill. To pull my tractor in, I took the right side wall boards off.
It has a shed style roof, and I plan to do a mirror image addition on the front. I'll take the front boards off, cut and reuse most of them on the new lower wall. I'll reuse the old right side boards on the new addition left side.
I used red cedar posts cut from my woods and now one has rotted through at ground level. So cut another 12 footer and placed adjacent yesterday. I was surprised how dry the ground already is while digging the hole. Also had to take down some adjacent gates and fencing. The carpenter bees were using one of the old cedar fence posts, and were not happy when I started hammering to remove fencing nails. I figured I'd give the few nails left until this morning when the bees are too cold to come out.
Pics ... ;)
:D
That were some beautiful pic of your trout fishing trip up in the Shennandoah ... we almost moved to area about 10 years ago ... lovely area.
   / Good morning!!!! #44,895
rswyan great job on grapple lots of thought and hard work.
Thanks.
Have you weighed it yet?
I have not ...
I might stick it in the back of the van at some point and run down to the scales, just for shizz and giggles ...
Thus far I have not run into anything that I couldn't pick up with it.
I do have a pile of logs that are around 30' long that I stacked up yesterday that could present a challenge tho' ... :rolleyes:
If I was still in steel fab business would definitely try to hire you
LOL ... thanks Bup ...
That's (IMO) probably one of the best kinds of comment a man can get :D
   / Good morning!!!! #44,899
... RS, that grapple is flat out marvelous and kinda mean looking, all good!
Drew,
Thanks for your kind words ...
I'm thinking of naming it "The Big Bite Grapple" ... :laughing:
How did you choose which cylinders to use and what spec to use for their strength?
I had a couple of criteria I used ... wanted the ports to be ORFS (O-ring Face Seal) to minimize/eliminate the leaking often found with NPT, welded construction (not thread-on clevis), and relatively cheap (I think have around $40 per cylinder in them, Surplus Center)
I went with 2 1/2" cylinders because the design wasn't really finalized at that point, and I was considering mounting the cylinders vertically, behind the masts/towers.
Ultimately decided not to go that route, because of the inherent mechanical disadvantage of the lever ... So they are actually probably somewhat larger than they need to be.
Only shortcoming they have that I can see, is that the rods are only 1" ... hopefully I won't bend one.
Do you have a Squeak Seat yet on your tractor?
No ... The Squeak continues to run to the door everytime anyone goes in or out tho' ...
She really wants to go outside ... in spite of me repeatedly warning her there are big kitty-eating things out there ... :laughing:
   / Good morning!!!! #44,900
71 was closed, at 7 am north of Ellinger, right at the Fayetteville cutoff. I had a Dr. Appointment in La Grange at 8 am so, had no idea if they would be open or not. Got a call at 7:40 that they were going to be closed. Stopped at Hruska's, in Ellinger, to drown my sorrows in a sausage, cheese, jalapeño kolache and a cinnamon roll.
2016 TRAILSTAR 40FT DUMP TRAILER (A56129)
2016 TRAILSTAR...
2833 (A58376)
2833 (A58376)
John Deere 6619 Power Unit (A57149)
John Deere 6619...
2013 Peterbilt 337 Single Axle Day Cab Truck, VIN # 2XP2AN7X4DM195257 (A57453)
2013 Peterbilt 337...
Giyi Mini Auger (A57149)
Giyi Mini Auger...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
