Puffs of blue smoke and white film on the tip of dip stick
   / Puffs of blue smoke and white film on the tip of dip stick #1
mikefrommichigan
I have a 5 year old cub cadet with a kohler engine.
I noticed that there was a slight oil drip on the floor after starting it up today after it was stored over winter in the barn.
I drove it for approx 15 minutes and noticed occasional puffs of blue smoke coming out of the exhaust. I checked the oil again and noticed a white film on the tip and along the edge of the dip stick.
Any help would be appreciated. Thanks
   / Puffs of blue smoke and white film on the tip of dip stick #2
Let me get this right. You stored it for the entire winter and didn't even check the oil before you started it up? Hummmm.
I did say "I checked the oil again" meaning a second time.
   / Puffs of blue smoke and white film on the tip of dip stick #4
Sounds like water in the oil
Is the oil turning mikly?
Check the breather and drain the fuel bowl. See if theres any water/condensation in either.
I would drain all the fuel out and refill with known, clean fuel. I would also change the oil and filter if it has one.
   / Puffs of blue smoke and white film on the tip of dip stick #5
Yep, What he said. Ed
   / Puffs of blue smoke and white film on the tip of dip stick #6
It's probably condensation from sitting all winter. Change the oil & filter or run it & see if it evaporates.
Changed the oil and filter today, fuel bowl and line inspection is next.
Thanks
   / Puffs of blue smoke and white film on the tip of dip stick #8
How did the oil look - was it balck, or did it have a brownish tint with possibly cream/white? When first drained was there any water?
2012 Ram 3500 Crew Cab Flat Bed Truck (A50323)
2012 Ram 3500 Crew...
2015 Kubota RTV-X1100C (A52748)
2015 Kubota...
2013 Isuzu NPR-HD 16ft Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
