MAX 22 4 years in
   / MAX 22 4 years in #1
kootch88
Gray, Me
2012 Mahindra Max 22, JD Stx38, JD Stx46
It has been 4 years since I got my Max 22 delivered and I thought some additional thoughts were in order.
The Bad first.
1. The paint does fade, not as bad as the older ones, but it is inexcusable in my opinion.
2. Front U-Joint cover design is poor, keeps coming loose.
3. Odd noise from front end when working on uneven ground.
The Good
1. The tractor is just built tough!!
2. Exceeded all expectations in terms of lifting, even knowing what the specs "claimed"
3. Comfortable seat and operating position. This is very important for a 6 foot person on a sub compact
4. Runs like a top, the Mitsubishi engine doesn't miss a beat.
5. Attachments work great, blower is a beast, the loader is very durable and easy to get on and off.
So, obviously the good far outweighs the bad. The odd noise in the front end is when the front wheels are going over large obstacles on the ground on one side only. I have looked for grease points and haven't been able to find where to lubricate the front axle pivot point. The u-joint cover isn't a huge deal, but when it is resting on the shaft it makes a nasty rattling sound. About once a year I have to re-attach the cover. The worst offense is the paint. Admittedly I have banged the tractor up a bit with dirt, some stone and the like hitting the hood, and I have washed the tractor not as often as I would like, but the paint is neither durable nor does it hold up well to the sun, and since my wife likes to park inside the garage, she gets priority.
I have about `180 hours on my machine, about 1/3 blowing snow, maybe 20 hours of mowing and the rest loader work. I love it and am happy I chose this machine. I guess the 25hp would have been better, but when is more horsepower not better?? :laughing:
   / MAX 22 4 years in #2
Thanks for the update. I have a max 26xl tlb with 20hrs now. the manual states to grease the front axle pivot point, but I cant find it, so not sure if manual is correct. Seeing dealer tomorrow. So far this tractor is all i could hope for and more. Very strong machine.
   / MAX 22 4 years in #3
The Bad first.
What is the odd noise? I sometimes have a "clicking" type noise that I get with stuff in the bucket. Can't tell where it's coming from.. It's intermittent so tough to pinpoint.
   / MAX 22 4 years in #4
I found I have an intermittent clicking, or rattling in my front end when driving without a load. It appears to be the bucket SSQA slide pins vibrating in the bucket holes they slide into. But I cant really tell as it only happens when I'm moving.
   / MAX 22 4 years in
If the dealer has a picture or you can snap one with your phone I'd love to see where that is!!
   / MAX 22 4 years in
It is a rubbng nosie, something in the pivot needs grease and I can't find where to get at it.
   / MAX 22 4 years in
Check the cowling around the Universal in the front, that was the sound is like when the cowling is loose, and it is mostly when going forward when it is loose. It has two set screws as well as 8 virtical screws. It is like a clam shell except is is round where it clamps around the rubber toward the back side of the shaft mount.
   / MAX 22 4 years in #8
hope this picture works
   / MAX 22 4 years in
Cramby, I know where the pivot is, what I don't see a Zerk in your photo, unless I am missing something. Surely they can't mean just trying to squeeze some grease in on the surface.
   / MAX 22 4 years in #10
I have the same vibration noise when empty
Sent from my iPhone using TractorByNet
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
2022 KUBOTA KX040-4 EXCAVATOR (A51242)
2022 KUBOTA...
2016 CATERPILLAR 257D SKID STEER (A51242)
2016 CATERPILLAR...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52128)
2-Row Peanut...
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
Takeuchi TL140 (A47384)
Takeuchi TL140...
