Afternarket Hydraulic Cylinder overhaul kits?
   / Afternarket Hydraulic Cylinder overhaul kits? #1
PeteinMilton
Milton, Ontario
Kubota B20 TLB
I have a Kubota B20 and need to rebuild the bucket cylinder on the backhoe, I am wondering if there is a source for aftermarket rebuild kits it the Toronto Ontario Canada area known as the GTA.
I want to try this myself but don't want to blow $100.00+ /kit doing it.
Thanks
Pete
I am surprised at the lac of response, either this topic has been done to death (not from what I can see in the archives),
Kubota Cylinders NEVER Leak or need repair (NOT!)
No one has found or no aftermarket manufacturers exist that make repair kits for Kubota cylinders?
I'm likely not going to ask on Orange Tractor Talks because of the host!
So what gives??/ Anybody??
   / Afternarket Hydraulic Cylinder overhaul kits? #3
Try contacting this seller on ebay to see if they have something and ship your way.
   / Afternarket Hydraulic Cylinder overhaul kits? #5
Whats the "kit" number?
Sorry the kit number is 75591-32300. the other number is for the stabilizer cylinder.
   / Afternarket Hydraulic Cylinder overhaul kits? #9
oem hydraulic cylinders are not as universal as you are thinking so you will probably never find someone that has a complete seal "kit". High end hyd/mfg shops can generally assist in a piece by piece format. So cylinder needs to be torn apart and take them the soft items. Otherwise the only way you will get a complete kit is to purchase from the oem, this is not unusual by any means.
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2020 JOHN DEERE CP690 LOT NUMBER 204 (A53084)
2020 JOHN DEERE...
2015 MAC FLATBED 48FT TRAILER (A52141)
2015 MAC FLATBED...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
