Yea, I think I might try a filter of some sort this summer on mine too, see if it works. This time of year I have no problem - the grass is always moist and don't have much seed & dust flying around, I can do my whole 6 acres without blowing the rad. out. In summer I usually have to stop twice or 3 times and hit it from the engine side with the blowgun, have to watch the gauge. About every 4 or 5 cuttings I take the battery out and go at it with the pressure washer, carefully. My washer is set on 2100 psi but it is a 5 gpm and will knock the snot out of anything it touches - of course I use a wide fan nozzle and keep back from the rad. to avoid damage. Also, if you use one of the good 'ol non-safety blowguns with the 12" metal nozzle like I do, take a short piece of 1/8" vacuum hose and stick on the end so you don't stab your rad. fins and bend them. I just can't imagine sitting there with a paper clip .....
Since it's spring again....I wonder. I wonder if those who cut a lot of grass every year and have this problem often; is there a replacement rad that might have more space between fins and clog less? A rad for something else that can be made to fit Mahindra with minor changes. It might be worth cost to change rad if it costs them enough hours every year cleaning rad. For me I don't get into high grass often enough to make any changes. Geeze, I could cut all the high stuff in rain if I have to. How this for an idea? I could cut all the high stuff in reverse.
Cheers.....Coffeeman
