Sizing a hydraulic control valve - size for pump flow, or total flow?
   / Sizing a hydraulic control valve - size for pump flow, or total flow? #1
jim_wilson
Northeast MA
Kubota B3200 w/ BH77 & 12", 18" & 24" buckets, Kubota B50 SSQA w/ 54" & 60" buckets, LandPride FDR1660, Artillian Fork frame, Extreme 3pt rake, Concrete Mixer, MyTractorTools grapple adapter
I'm working thru a setup I want to install on my Kubota B3200 for a hydraulic thumb on the backhoe. The specs list the "pump flow" as 6.7gpm - and the "total flow" as 9.9gpm. The "steering flow" is listed as 3.2gpm. Steering flow + pump flow = total flow.
Do I need to size the GPM of the valve for pump flow - or total flow? Is the steering system typically completely separate from the regular hydraulics?
   / Sizing a hydraulic control valve - size for pump flow, or total flow? #2
Backhoe will get pump flow only. It is difficult to find valves rated less than 10 GPM so 6.7 or 9.9 won't make any noticeable difference.
Thanks. I've been looking at two different Prince valves that I think will work - one is rated 8gpm and the other is rated at 14. The B3200 has the 6.7gpm pump flow - and the 8gpm valve is cheaper than the 14 , so I was hoping the 8 would work.
   / Sizing a hydraulic control valve - size for pump flow, or total flow? #4
the 8 GPM would be the better choice.
   / Sizing a hydraulic control valve - size for pump flow, or total flow? #5
It would seem counter to good sense to demand a full flow capacity valve, and then maybe put a flow restriction on it to keep the actuator speed in line .....
If the valve is part of a power beyond system, then flow from inlet to outlet should match system flow to keep restriction and heating to a minimum.
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
Tafe 45DI (A60462)
Tafe 45DI (A60462)
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
