2010 DK55 480 hrs + accesories price check
   / 2010 DK55 480 hrs + accesories price check #1
realhunter
Shoals, IN
LS XR4150
From the Add-
2010 KIOTI DK55 4 W/D WITH R4 TIRES
12 SPEED SYNCRO SHUTTLE SHIFT TRANSMISSON WITH 440 HRS.
55 HP 4 CYLINDER DIESEL
550 RPM AND 1000 PTO
2 SET OF HYDRAULIC OUTLETS
DELUXE 3 P0INT HITCH WITH EXTENDABLE ARMS
CAT 2 HITCH.
REAR HYDRAULIC LIFT CONTROL.
TRACTOR IS IN VERY GOOD CONDITION, ALWAYS STORED IN BARN.
THIS LOADER WELL PICK UP 3,200LB.
ALSO INCLUDED IS, A BRAND NEW CLAM FORKS, A SET OF FORKS. ( Tomohawk )
AND A 7 FT. WIDE WOODS REARS BLADE
6 FT. BRUSH HOG MOWER - ( Canadian made ) - Who makes that?
Pallet forks
Bucket
Price - $26,500
   / 2010 DK55 480 hrs + accesories price check #2
If the tractor and implements are in good condition that's a good deal. The tractor isn't actually optioned out, everything except the 2nd remote is standard on the DK. The synch shift is the only tranny available for the 55. If I recall, the 55 has a turbo engine, if that matters to you. Obviously check it out, but if it's as advertised and it's what you want, go for it.
Thanks for quick response!
I haven't used a synch shift.
My experience has been on JD's with the PowerReverser...
Is this a similar set up?
   / 2010 DK55 480 hrs + accesories price check #4
Yes, same general gear set up. However, you cannot shuttle from forward to reverse without using the clutch. To change direction you must put the clutch in, then move the shuttle lever. I do not believe the tractor needs to be at a complete stop to shuttle or shift gears. A lot more clutching with a straight gear (what this is) than with a Power Shuttle.
   / 2010 DK55 480 hrs + accesories price check #5
Ive got a 2012 DK 55 with 325 hrs for sale for $21,000...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
John Deere WG48A 48in Walk-Behind Mower (A51691)
John Deere WG48A...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
2017 Nissan Frontier Ext. Cab Pickup Truck (A51692)
2017 Nissan...
