Lakeside Electrical
   / Lakeside Electrical #1
lakngulf
Lake Martin Alabama
Kioti CK30
I have been reading about major problems with electricity on piers and near water. While I think my setup is good and has worked for years I think I want to install a complete shut off switch where wire leaves house and heads toward the water. What is a good switch to accomplish this?
   / Lakeside Electrical #2
How often will you switch it off? Can you just use a breaker?
For the power to my pier, I have a series of breakers. The first breaker is in my main panel in our house, a 30A double pole breaker. Wiring runs from there under the house, then underground to the top of the stairs to my pier, about 200' away. There, the wiring goes into a weather resistant main lug panel with a 30A double pole GFCI breaker -- so everything downstream of that is GFCI protected. Wiring then runs down the stairs another 50' or so, into another weather resistant panel on the pier. That contains a 15A single pole breaker for a receptacle, and a 20A double pole breaker for my boat lift.
When I stop using the pier in early winter, I will shut off the 30A breaker up inside our home. Or if we will be out of town for more than a few days I will shut it off.
For routine use during the boating season, I switch off the 15A and 20A breakers on the pier when power is not needed. I don't want power going to the boat lift control unit unless I am down there actually needing to use the lift.
   / Lakeside Electrical #3
Any of the outside AC switches should work fine if you just want a way to turn off the power. I would also have everything on the pier run through a GFCI outlet before it gets to the pier if possible.
   / Lakeside Electrical #5
How are you preventing the 30amp two pole line to line GFI from tripping when using a single pole likne to neutral load downstream?
   / Lakeside Electrical #6
How are you preventing the 30amp two pole line to line GFI from tripping when using a single pole line to neutral load downstream?
Perhaps it's a " single phase, 3 wire" GFI breaker (i.e. GFI breaker has a third line side (neutral) terminal) ?
(e.g. Like a Siemens QF230-30)
   / Lakeside Electrical #8
I read up on this many years ago -- most dual pole GFCI breakers are setup to handle this. They are able to sum all current from both legs and the neutral, and if it's not a net zero, they trip. So it doesn't matter if the imbalance is between the two hot legs, or one of the hots and neutral.
   / Lakeside Electrical #9
How many amps are you sending to the pier and is it 240v or 120v
Home Depot and Lowes both sell cutoff switches commonly used for A/C units.
For a "complete shut off" the two best choices would be a Knife style pull switch or one where you "pull" the cutoff out - they both ensure "NO power" when they are in their "off" position.
It is a 120V 20 amp. I know of the AC cutoffs you mention. I will look for the Knife style pull, I like that idea.
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A53472)
2004 Capacity Yard...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A53472)
Koyker Loader...
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
ECHO CS-3510 CHAIN SAW (A51248)
ECHO CS-3510 CHAIN...
